Results 16 to 30 of 33
Thread: well pressure gauge
  1. #16
    Jan 2008
    Virginia Beach, VA
    If the tank is 20 years old I'd remove it and consider installing a Pside-kick under the counter. The Pside-kick includes a new 5 gallon tank, a new pressure switch, guage and other required components. http://constantpressurekits.com/products/pk1a. The Pside-kick will give you constant pressure, prevent the pump from cycling and you'll only hear a clicking of the pressure switch when it shuts off.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  2. #17
    Mar 2011
    Houston, TX
    Quote Originally Posted by Porky View Post
    Under the counter ?
    How much wire is required for that ?
    I guess not much if your pump is under the counter also.
    I must have missed something.
  3. #18
    DIY Junior Member sherr's Avatar
    Sep 2013
    carol stream, il.
    I don't have a way to tell how many gallons my tank is....as it is in the ground. I have a pumptrol switch 20 40 psi , GB industrial . I just know if the gauge is on 60 when I turn on the kitchen faucet ....it takes 1 1/2 minutes to drop to 44 then the pumps comes on and shuts off at 62 ....keeps cycleing that way til I shut water off. to me it seems like that's too short of time. i cant tell how often it cycles when i shower, i live alone.....I guess ill call my well guy.
  4. #19
    Sep 2013
    carol stream, il.
    under the kitchen sink ?? .....i guess i could give up a different kitchen cabinet . i will go thru 5 gallons quickly wont i ?? also.... i am on a slab home no closet space unless it is removeable. so i can get at hot water heater, furnace washer/ dryer , softner and the utility box. that closet has no room.
  5. #20
    Sep 2013
    carol stream, il.
    and truth be told he water tank is from 1987.. !!!
    how long does one last and how can you really tell it is shot.
  6. #21
    Sep 2013
    1. You have a way to measure how much water comes out of your sink during your 1.5 minute test. If your bucket is not marked, calibrate it by pouring quarts of water into your big bucket. If your bucket will not fit under your faucet, close the drain on the sink. Calibrate your sink. How long does it take to fill the sink (or bucket). How big is the sink (or bucket). Based on that, you will know the flow rate from the sink.
    Let T = the number of seconds to fill your sink or bucket.
    Let G = the number of gallons to fill your sink or bucket.
    The flow rate will be G/T/60.
    The number of gallons that you can use before the pump goes on is about 1.5 times the flow rate. That will actually be an over-estimate, since the flow rate drops as the pressure decreases.
    Let your kids help with the math if appropriate. It will be motivating in their studies.
    You could avoid the math and use a 5-gallon bucket fed by a hose or the laundry sink tap.
    2. You have a watch that can measure the time from when the pump turns on, until it turns off. In fact, you could try measuring that with the kitchen faucet on and off. But if you only measure one way, do that with the faucet off. If that time is under 30 seconds, call your plumber or well person. If that time is over 55 seconds, don't call. If it is in between, think about it.
    3. If you provide the external measurement of your pressure tank, somebody could tell you the approximate size of your tank, and tell you what your expectations should be for test #1. If you cannot measure your tank, that's is OK. If you are getting 5 gallons of water during your 1.5 minutes, your tank is fine. If you are getting 2 gallons, your tank is not fine. In between... ??? Do you have room for an inside tank? It is OK to have 2 tanks.
    I feel that you are probably not going to be into DYI, even if it only involves using a tire pressure gauge and a tire pump. That would be the bit that could optimize the pressure tank that you already have. Maybe you don't have access to the air valve for your underground tank, so that would be a reason to call the pro.
    My opinions only... not a pro. I have provided estimated criteria here. Criticism is welcome.
  7. #22
    Sep 2013
    carol stream, il.
    i just found out it is 44 gallons !!!
  8. #23
    Feb 2011
    NW Ontario, Canada
    That size tank at 30/50 PSI setting should give you about 13 gallons before the pump turns on.
    Have you measured how many gallons you get like I asked you?
  9. #24
    Sep 2013
    carol stream, il.
    it stops and holds ...when i turn water off.
  10. #25
    Sep 2013
    carol stream, il.
    i believe it draws just less than 3 gallons in the 1 1/2 minutes draw time before pump comes back on. comeson at 44 off at 62-64. really.
    it must come on a bunch of times when i take a shower. so im trying to decide if it comes on too often
  11. #26
    Sep 2013
    carol stream, il.
    i guess i'm calling a well guy. with the kitchen faucet running.....it takes 15 seconds from pump kicks on to pump shuts off. i
  12. #27
    Mar 2011
    Houston, TX
    Quote Originally Posted by sherr View Post
    Sounds like a tank problem. May be water logged.
    Good Luck
  13. #28
    Moderator valveman's Avatar
    Mar 2006
    A good 44 gallon tank only holds 12 gallons of water. I agree yours is only holding about 3 gallons, so the bladder in the tank is busted. I am sure it is cycling a lot of times while you take a shower. But even with a new 44 gallon tank it will cycle 2 or 3 times during a normal shower.
    The Pside-Kick with the 4.5 gallon tank (1 gallon of water) has a Cycle Stop Valve (CSV) so the pump will never cycle while the shower is on, even if you take a month long shower. Your water doesn’t come from the tank, it comes from the well and pump. A CSV will adjust the output of the pump to match the amount of water being used, so the pump never cycles, even with the little 4.5 gallon tank.
    In other words, the CSV and small tank will do a better job than the biggest tank you could get through the door. The Pside-Kick kit sells for $399, a new 44 gallon tank ???
    So called “normal cycling” is what busted the bladder in the tank you have, like bending a wire back and forth until it breaks. Cycling is also very bad for the pump. Ask your well guy about a Cycle Stop Valve. They have been saving pumps and tanks for over 20 years. If he hasn’t heard of the CSV, he doesn’t get out much.
  14. #29
    Mar 2011
    Houston, TX
    The price of a new tank would be about the same Installed, In my neck of the woods.
    Seems like a CSV would be a good choice.
    The Pside-Kick kit will install at your old tank location.
    To install it in your house would require a bit of wire, and would have voltage drop to your pump.
    Good Luck.
  15. #30
    Sep 2013
    carol stream, il.
    my guy hasn't called back yet... but thanks... its a big , many many years of service company [family owned[ I have complete faith in them.
    if it comes to new tank..... like I said mine is currently in the ground......I gotta find space in my tiny house. thanks for helping. ill let you know what they say.
  1. Low water pressure, pressure tank gauge
    By epeloke in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2012, 07:03 PM
  2. Water hammer bouncing pressure gauge needle AFTER pressure tank fills
    By hawkhunter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2012, 10:35 AM
  3. Do I need a pressure gauge?
    By 1jackw in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-29-2011, 10:28 AM
  4. Is my pressure gauge shot?? low water pressure.
    By help4steveo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-15-2010, 04:33 AM
  5. Well pressure gauge
    By Gpace1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-12-2010, 10:16 AM
