Results 1 to 7 of 7
Thread: American Standard two handle tub valve
    Default American Standard two handle re-nu tub valve
    Anyone familiar with these? I believ it is a re-nu. Stem leaks at front seal where marked with red arrow only when water is running. Gasket at that point doesn't seem to be compressing when I tighten the cartridge. Seat on the body looks good. Another plumber told me the body was most likely cracked, so I removed it. I can't see anything wrong.
Size:  99.6 KBHere is a pic of the cartridge assembly. The barrel (back end) of the stem seems to be seating because the tub spigot doesn't drip water when shut off. It's almost like the assembly is "too long". If I remove the brass washer between the barrel & the stem portion, it seems to tighten up just fine, but I'm not sure that removing the washer is OK.
    Removing the washer would be one reason why it would leak there. Is there a washer between the two pieces?
    Yes, the brass washer is there. (blue arrow. That's the washer I'm talking about removing). there is also a rubber washer where the red arrow points to, but with everything tightened down, it is barely compressed. Like I said, it's like the stem assembly is just a bit too long.
    So I removed the brass washer, which basically makes the cartridge about 3/32" shorter & everything works just fine. Just not sure why. Anyone have any idea who I could call for advice on this?
    As long as it works, nobody. Your "Re-Nu" barrel has the "O" ring on the end so it does not need as much pressure to seal it to the valve body as the old "all brass" ones did. Yours also has the newer "straight" sides, rather than the "necked down" end of the older sleeves, which your valve probably had originally, and might also make a difference.
    Thanks. I cleaned it up, and reinstalled it and am just thrilled that after 80 years, it works, and looks like it could go another 80 years.
  1. Need help identifying an American Standard two handle shower cartridge
    By steelpeart in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2013, 10:02 PM
  2. Pfister or American Standard 2 handle shower valves
    By Shelly in forum Shower & bathtub Forum & Blog
    Last Post: 10-23-2013, 12:58 PM
  3. American Standard shower valve
    By perrymiles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2012, 09:27 PM
  4. Leak in American Standard single-handle shower valve
    By VT Pats Fan in forum Shower & bathtub Forum & Blog
    Last Post: 12-20-2006, 05:43 PM
  5. Leaking American Standard single handle shower faucet
    By VT Pats Fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2006, 01:24 PM
