chasmosis1
I'm aware that Rusco makes one, but it is $350 on the low end. According to their website it has an adjustable cycle time from 5min. To 24hrs. with a 3sec. Flush time. This got me thinking why not just run a good high quality brass electric solenoid valve such as this http://www.amazon.com/Electric-Solenoid-110-VAC-Normally-Closed/dp/B007N0J98E that is normally closed and just run it through a timer? Of coarse the minimum run time for most 7/24 timers is 1min., but by placing a delay timer in line after the 7/24 you could than make the flush time any amount in seconds. At this point you would be at less than $100, and you could adjust your flush time up to 7 days rather than a 24hr. max.
Input would be appreciated.
