Thread: Toto Aquia Temporary Install on Concrete Floor
    DIY Junior Member ipedalfaster's Avatar
    Oct 2013
    Portland, ME
    Default Toto Aquia Temporary Install on Concrete Floor
    I have a Toto Aquia (10" rough-in) that I am ready to install in downstairs bathroom which has a concrete floor. There is a 50/50 chance that I will eventually tile the floors of this bathroom and I am wondering how difficult it will be to re-install the toilet atop the new tile if choose to go that route or if (because of Toto's mounting system) I will be forced to tile around the unit?
    Has anybody had any experience with this (in particular with a concrete floor)? Any insight(s) would be greatly appreciated.
    Thank you!
    The Aquia bowl sets on the finished flooring.
    You can set the bowl now, with the mounting blocks to the floor, but then after the new floor, you will need to reset the blocks.
    We carry a rotohammer for those installs.
    First suggestion - SAVE THE TEMPLATE! It's not a big deal to remove the mounting hardware, then reinstall after you add tile. You may then need to either stack or use a jumbo wax ring to make the seal if you can't or don't want to move the flange up on top of the finished surface. You may need to buy a diamond core bit to drill through the tile (Lowes carries one brand), but it depends on the tile. Some tile can be cut with a carbide drill bit, but some porcelain is almost as hard as diamond, and laughs at the carbide!
  1. Toto Aquia install in remodeled bathroom, 11-1/4" rough in
    By lifespeed in forum Toilet Forum discussions
    Last Post: 05-16-2012, 09:01 PM
  2. Toto aquia III install
    By mcdonaldb in forum Toilet Forum discussions
    Last Post: 11-18-2010, 11:00 PM
  3. Toto Aquia Install Issues
    By AnnoyedTotoOwner in forum Toilet Forum discussions
    Last Post: 11-17-2007, 08:42 AM
  4. Toto Aquia install
    By rmac-aquia in forum Toilet Forum discussions
    Last Post: 07-18-2007, 12:26 PM
  5. Need advice on how to properly install floor drain in concrete slab!
    By Chris Tittle in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2006, 09:09 PM
