Results 1 to 6 of 6
Thread: I need help with hydronic heating installation
    DIY Junior Member SAVROOM's Avatar
    Oct 2013
    mountain view, ca
    Default I need help with hydronic heating installation
    I don't see a hydronic heating-specific forum here....am I overlooking it? I'm in the process of designing and installing a hydronic heating system in my home and have a number of technical questions.
    Could someone point me to a forum dedicated to helping non-plumbing professionals with hydronic heating systems?
    Edit: adding a zone diagram....does this make sense to anyone that understands hydronic design?....appreciate any comments. I'm using Runtal radiators, a mix of wall and vertical style radiators.
    Most of us would probably use a single pipe MonoFlo system, but the two pipes system MAY work better when most of the valves are closed. It is just more expensive to do it that way.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    GO TO THIS WEBSITE
    http://www.heatinghelp.com/
    THEY HAVE THE ANSWERS
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Oct 2013
    mountain view, ca
    I was told by the Runtal rep that in a mono-flo system the water is cooler by the time it get's to the last radiator...which makes sense to me since each succeeding radiator is draining heat from the water. He said the parallel piping will ensure a consistently heated water supply to all radiators simultaneously....and looking at the design I believe he is correct.
    He said that mono-flo systems are preferred by some installers because they're cheaper and easier to install but not necessarily best for the customer.
    Also, I don't understand the statement "two pipes system MAY work better when most of the valves are closed". Please clarify why you believe this to be true....to me that makes no sense.
    Oct 2013
    mountain view, ca
    Mods, please move this thread to the HVAC forum...thanks.
    Nov 2010
    Maine
    Your diagram is the preferred method for piping radiators, convectors and flat panel radiators. It gives the least temperature variation and the least pressure drop across the system. It may or may not be slightly more expensive due to the extra piping needed but, monoflow tee's are pretty pricey and I suspect that the cost difference is minimal. I have a similar arrangement in my own home using 5/8" heat pex so the cost of the piping is negligable. If you are hooking everything up to a Mod-Con boiler you will need either a differential bypass or a tempering valve on the return side to keep the return temperatures in the condensing range. If its a standard, non-condensing boiler you will need to bleed some feed water back into the return to keep it from condensing.
  1. Hydronic subfloor heating help.
    By Colleen Joudrey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2012, 07:18 PM
  2. At wit's end with broken hydronic heating system
    By TGL11 in forum HVAC Heating & Cooling
    Last Post: 12-15-2007, 04:29 AM
  3. Hydronic heating problem
    By guga in forum HVAC Heating & Cooling
    Last Post: 09-22-2007, 06:47 PM
  4. One-Pipe Hydronic Heating
    By techno in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2006, 03:57 PM
  5. PEX Connectors for Hydronic Heating
    By LarryK57 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2005, 07:44 AM
