Thread: 1980s American Standard diverter issue
    DIY Junior Member jbass524's Avatar
    Oct 2013
    Northern California
    Default 1980s American Standard diverter issue
    We have an older American Standard shower fixture with, what seems to be, a bad diverter valve. Water to the faucet or shower head is never completely on or off.
    I've looked all over to try and find any evidence of the model and/or replacement parts. Any help in finding some information would be appreciated.
    A solution other than replacing the whole thing would be incredible.
Size:  22.3 KBName:  IMAG0017.jpg
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    You should be able to remove the handles and escutcheon plate. Then remove the cold and hot stems. You can replace them and the seats if needed. While you are doing that also replace the diverter stem.
    Hot and cold stems
    http://www.faucetpartsplus.com/categ...show=10&page=2
    Diverter
    http://www.faucetpartsplus.com/category_s/246.htm
    https://www.youtube.com/watch?v=yNhXAPKwoAM
    https://www.youtube.com/watch?v=2VoO3o6crvs
    Oct 2013
    Northern California
    Quote Originally Posted by Smooky View Post
    Hot and cold stems
    Diverter
    Thank you Smooky. It sounds like a diverter and the stems aren't so particular to a model but to a dimension.
    Will I need to measure and compare what I take out to the one I order or is there another designation I need to look for on the parts I remove?
    Thank you again for your time.
    Apr 2011
    NC
    Turn off the water and let it drain out. It is good to turn off the hot water heater while the water is off. Take out the hot and cold stems and the diverter. Take them with you to a hardware store. Most big box hardware stores have books with pictures of stems or there may be examples to look at and compare. Match up what you have and get a match.
    http://www.homedepot.com/s/webapp/ca...earchAll#/?c=1
  1. American Standard Diverter Problems
    By labumm in forum Shower & bathtub Forum & Blog
    Last Post: 03-13-2012, 09:38 PM
  2. Wanting to Replace 3 1980s American Standard with 5 Totos...
    By Raspvalley in forum Toilet Forum discussions
    Last Post: 07-16-2010, 09:26 PM
  3. American Standard Diverter Problems
    Last Post: 01-05-2010, 07:29 AM
  4. American Standard Diverter problems
    By millsde in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2008, 06:08 AM
  5. American Standard diverter
    By Guest in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2006, 01:20 PM
