Results 1 to 4 of 4
Thread: Drain into fresh air inlet..
Threaded View
    DIY Junior Member hagakure's Avatar
    Aug 2012
    nyc
    Default Drain into fresh air inlet..
    ..right above where it meets the main? My mother bought a house and I am extremely limited with what she and my step father will allow due to stubbornness and money and the only available pipe to dump a half bath from the first floor is the FAI which the previous owner had buried into a wall for some strange reason. I want to cut the pipe before the elbow, close to the main, put a wye and dump the 3 inch from half bath into it, then connect a new FAI into the top of said wye and not bury it in a wall this time.
    I will be using PVC for the half bath but am unsure of what the best option is for connecting to the snapped Extra Heavy 4 inch. Can sch 40 PVC connect to a hubless piece of XH pipe? Before looking like an idiot at the plumbing supply I figured I'd look like an idiot here. I just want to make sure first but I really can't think of a problem other than some obscure local code.
    Thanks a lot. After doing commercial for 3 years its a pain in the ass to see 80+ yr old plumbing and have to fix it cheaply.
  1. Corroded inlet pipe to water heater and drain issues?
    By snetsie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2012, 08:15 AM
  2. Water running out fresh air inlet pipe
    By DaveHo in forum HVAC Heating & Cooling
    Last Post: 08-09-2011, 07:25 AM
  3. My septic tanks inlet is lower than my commode drain
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2008, 02:31 PM
  4. Why should dishwasher drain go to disposal inlet?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2007, 08:14 PM
  5. PVC Fitting - Using Elbow w/inlet w/toilet drain
    By hmmdinger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-17-2005, 11:22 AM
