Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Water heater expansion tank
  1. #16
    IF the tank is set at the house pressure, there will be little, if any, water in it.
  2. #17
    That's not how it works in Seattle.
    Here, when you have an expansion tank, and turn the water off, it takes a while for the water to quit draining. It's like a delayed shutoff.
    Without the expansion tank, off is off.
  3. #18
    DIY Senior Member Reach4's Avatar
    Sep 2013
    I laughed at that one.
    Then I thought, what if the tank was pre-charged with 60 PSI of air and the city supplies 60 PSI water? Maybe that tank would do a better job of being able to accept over-pressure water, as the water heated, than if the tank was pre-charged with less.
  4. #19
    Quote Originally Posted by Reach4 View Post
    That's how they are supposed to be installed...set the precharge to your NORMAL water pressure, then the bladder is at equilibrium, providing the full capacity of the tank, and not having to be stressed as much by overstretching it. Now, when the WH causes the water to expand, it has the full capacity of the tank to absorb it. When you open a tap, the ET will release the water it is storing, and be ready for the next time the WH is running.
  1. Water Heater Expansion Tank
    By Roccoo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2009, 04:55 AM
  2. Location of expansion tank w.r.t. water heater
    By jdf405 in forum Tankless Water Heater Forum
    Last Post: 07-10-2009, 01:34 PM
  3. Expansion tank needed on water heater?
    By Mike16 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2008, 06:01 AM
  4. Expansion Tank for a Hot Water Heater
    By driem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2008, 06:01 AM
  5. No Expansion Tank for Water Heater
    By vasanvasan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2006, 06:34 AM
