Thread: New shower install: Mortar vs felt pad.
    DIY Junior Member Montazh's Avatar
    Oct 2013
    Seeley Lake, Montana
    Question New shower install: Mortar vs felt pad.
    I am installing a new Sterling Accord shower, about 3' X 5' base. Directions said to install the felt pad underneath the base but there was no pad included, as I see others have also experienced. Viewing Sterling's instruction videos it appears that I could substitute roofing felt (tar paper) or use mortar.
    Again watching Sterling's instruction video it appears that the mortar is not mixed with water... just put in dry. Is that correct? If the mortar is mixed with water... the video did not indicate it was troweled smooth but put in rough. Your assistance is greatly appreciated!
    Thanks for your valuable service!!!
    Ron
    If you use mortar, it is mixed first.
    The reason it goes in rough, is so that the pan can squish it out to conform. If you try to make it flat, which I find impossible, then you may as well go with the roofing paper.
    Jan 2008
    Set 10-12 small piles of mortar, and then set the base down straight on top of the piles so that the piles "squish" into the bottom honeycomb. Don't use too much water in the mix, you want the piles to be stiff yet "squishable".
  1. Bathtub Install With Mortar
    By JD3263 in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2013, 09:11 PM
  2. Replies: 1
    Last Post: 09-01-2010, 11:58 AM
  3. Wall Mount toilet - replacing felt/wax
    By steveewf in forum Toilet Forum discussions
    Last Post: 10-13-2008, 05:09 PM
  4. Mortar under Shower
    By molo in forum Shower & bathtub Forum & Blog
    Last Post: 01-14-2007, 11:01 PM
  5. use of plastic or felt paper behind cbu
    By barrybpdx in forum Remodel Forum & Blog
    Last Post: 09-18-2005, 07:07 AM
