Results 1 to 5 of 5
Thread: standard electric water heater
    Default standard electric water heater
    Given I live alone and have very low hot water usage, Dana recommends I get a well insulated standard electric tank over gas, given that standby loss is more important than cost of the source.
    Does any of the following make any real difference?
    - 9 year warranty with 2 inch foam insulation and 1 anode rod. Or 12 year warranty with 3 inch foam insulation and 2 anode rods.
    - Anode rod aluminum versus magnesium.
    - Overheat protection in GE literature, not in the other brand's lit (Kenmore).
    I can’t tell if Kenmore (A.O. Smith or State I heard) is a good deal or not. But GE (Rheme) at Home Depot seems no better in internet reviews. Brands like Bradford White are not available to the public.
    I'm favoring Sears on its 9-year tank that offers a full 9 year warranty - parts, labor, replacement install if needed, but then I see a plastic valve at the photo bottom, not brass, so wonder if it is cheaply made.
    http://www.sears.com/kenmore-38-gal-...&blockType=G12
    Mar 2011
    Houston, TX
    They are ALL made cheap now a days.
    They all have Overheat protection.
    The sears would be just fine.
    There is not all that much to go wrong, but service after the sale is a plus, and sears has the techs and parts to fix it.
    Good Luck.
    The drain valve is often replaced, and it's easy to do. I favor a 3/4" ball valve with hose adapter.
    Thank you! Just what I needed to hear. And the Kenmore just went on a Columbus Day holiday sale.
    The bigger differences between brands is in fired WH, not electric. More insulation is good. The choice of anode material is somewhat dependent on your water chemistry. In some water chemistry situations, the anode can react and create some funky water smells. If that happens (any plumber in your area would know), you'd swap it for a different type.
  1. Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 09:01 AM
  2. Electric Hot water heater.
    By 4hplar in forum Water Heater Forum, Tanks
    Last Post: 06-20-2009, 07:54 AM
  3. Best Electric Water Heater???
    By hawkmanz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2008, 08:26 AM
  4. ELECTRIC Water heater
    By KAYTEEB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2007, 02:18 PM
  5. electric hot water heater
    By rdema19403 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2006, 06:52 PM
