Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: What makes compression fittings leak?
  1. #16
    DIY Senior Member guy48065's Avatar
    Sep 2013
    SE and north MI
    Well then I AM doing it wrong. I always thought ferrules were supposed to be crimped on so they can never move. Permanent. If I had to estimate the torque I typically use I would say maybe 10 foot-pounds on a 3/8 line.
    Romeo and Atlanta, MI
  2. #17
    Mar 2011
    Houston, TX
    Normally the ferrule will bite into the tubing, and if the connector needs replaced, you need a new ferrule and need to cut back to a new place on the tubing.
    The copper does get pinched, and the ferrule will not move on the tubing, after you tighten it then take it apart.
    Have Fun.
  3. #18
    The fitting doesn't need to be so tight it deforms the pipe to seal. You can make it tight enough to deform the pipe, and if you do, would need a puller (or cut it off) to remove it. Since that isn't uncommon is one reason why the tool exists. I haven't taken that many apart, but on those that I have, they weren't leaking, and I was able to pull the ferrule off without needing a tool. All that's required is intimate contact, not a depression or crimp effect.
  1. compression fittings
    By Bruce Hoyt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2008, 02:09 PM
  2. compression fittings
    By dmetz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2007, 12:21 PM
  3. Compression fittings
    By Luken8r in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2006, 08:54 PM
  4. Compression fittings for PEX
    By themax3000 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2004, 08:29 AM
  5. Compression fittings for PEX
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-19-2004, 02:17 PM
