Results 1 to 6 of 6
Thread: Installing a replacement water softener
    DIY Junior Member migoblu's Avatar
    Oct 2013
    Default Installing a replacement water softener
    I have a Model 900 Water Boss water softener that I am replacing with either an exact Model 900 Water Boss, or another brand. I am leaning to the Model 900 Water Boss as I won’t have to cut or solder any water lines. If I replace the old softener with a different brand, I know this is probably not possible, but can I run a garden hose from the Model 900 Water Boss water line connectors to a water softener that may be taller than the Water Boss, or is there anything such as flexible water hose/lines that I can use? Thanks for any help.
    Nov 2010
    Maine
    Yes there is
    Jan 2012
    California
    Like these?
    Oct 2013
    Thanks for your reply.
    Oct 2013
    Like these?
    Thanks, those will probably work just fine.
    Nov 2005
    Central Florida
    How do Falcon SS connectors compare with PEX in price & performance? Obviously PEX requires a little more "D" for the DIYer.
  1. Question for installing sediment filter and water softener.
    By HiccaBurp in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-11-2011, 11:52 AM
  2. Installing Water Softener
    By jacksmith7 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-13-2009, 03:31 PM
  3. Installing Water Softener
    By jacksmith7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Installing water softener in basement
    By rpru in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2007, 08:24 AM
  5. Low water pressure after installing filter/softener
    By EricRLarson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2005, 08:41 PM
