Thread: Best wax ring for Drake 2 = ??
    DIY Junior Member Giman's Avatar
    Oct 2013
    California
    Default Best wax ring for Drake 2 = ??
    Want to know which brand and model is best for Drake 2.
    Whichever one is thick enough to have some compression when the toilet is placed on it.
    Expanding on what HJ said, it really depends on where your toilet flange is relative to the finished floor. By design, a toilet flange should be on top of the FINISHED floor, and if it is, pretty much any wax seal you use should work. If it is high or low, you could have issues (high, meaning it is floating in the air, and not properly supported may mean the toilet won't fit at all!; low, you may need a thicker wax ring or to stack a couple). There's one exception - when only using one wax ring, especially on a 3" pipe or an offset flange, do NOT use one with a funnel in it. When pressing it down, that plastic funnel can get squished nearly closed and create all sorts of problems.
  1. Noise matters: Drake, Eco Drake, or Drake II?
    By RandySea in forum Toilet Forum discussions
    Last Post: 07-20-2012, 06:47 PM
  2. Toto Drake: 1.6GPF vs 1.28 GPF - Is 1.28GPF Drake just as good??
    By goshenplumber in forum Toilet Forum discussions
    Last Post: 08-09-2010, 10:53 PM
  3. Power Gravity (blue) Flapper in a Drake & Drake 2 (Gwyneth)
    By tyneskj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 03:27 PM
  4. Toto Drake - Pink Ring
    By js0873 in forum Toilet Forum discussions
    Last Post: 05-07-2007, 05:38 AM
  5. Wax ring with horn on a Drake.
    By Guy in forum Toilet Forum discussions
    Last Post: 01-25-2006, 09:27 AM
