F&W deep well jet pump replacement
If that pump is just rusty and still working, I would knock off the rust and paint it with Epoxy Enamel paint.
I agree-- why replace a working pump? If the rust bothers you, I would brush on POR-15 Rust Preventive Paint as a primer under any top coat. http://www.por15.com/POR-15-_p_8.html It can also be used without a top coat. It becomes a dull dark grey to black if there is no top coating, but it does cover and then inhibit rust.
DonL
Houston, TX
It might have been Simer, if they were making plastic pumps a generation ago. Easy enough to find an image of the ubiquitous pump. One of the results has the Simer name on the same pump.
This thread was about a deep well cast iron jet pump, not a single stage plastic crap, crap.
Make sure you make a copy of your disappearing ink thermal receipt, Because you will need it.
Have Fun.
