Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: F&W deep well jet pump replacement
    DIY Junior Member schudaddie's Avatar
    Oct 2013
    michigan
    Default F&W deep well jet pump replacement
    I'm currently trying to figure out what pump would be suitable to replace my F&W deep well jet pump (three stage, 1hp). It's date code is 76H3 and is a model C6279. It seems to work OK but due to it's age the casting is rusting and flaking off. It might have been installed in 1977 because that's when my 2" well was installed. From the paperwork from the driller the screen is set between 116' and 220' down. The fitting on the bottom of this vertical pump looks to be a single 2" pipe running horizontally out of my basement about 2' under the ground surface. F&W's website doesn't mention a 3 stage. Only 2 stage. Most of my searching online mentions a 2 pipe. I would just like to swap out my pump as my finances won't allow a new well etc. I did come across this pump (Flotec 1 HP Multi-Stage Deep-Well Jet Pump) at a reasonable price from home depot but I don't know if they are reliable etc. any info on this topic would be greatly appreciated.
    thanks for your time, schudaddie
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    I recommend that you call Flint and Walling at 800-345-9422 http://www.flintandwalling.com/fwhome and present your questions. A Flotec would probably be my last choice.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I agree with Porky
    Around here Flotec is a 6 letter word for junk
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Pardon my intrusion, but I didn't want to have a new thread for the following question on Flotec and related products. The question is whether or not Pentair has maintained sufficient separation of its various pump brands, to the effect that one of their brand names still counts for as good a product as it was before acquisition. I've seen some pumps get new brand names, like the Berkeley SSHM-2 shallow-well jet pump getting a Sta-rite label and model number.
    Oct 2013
    michigan
    Quote Originally Posted by craigpump View Post
    I'm agree with Porky
    thanks so much for the scoop on f%#tec. sound like contacting F&W is the way to go......
    later, schudaddie
    Mar 2011
    Houston, TX
    If it is made of plastic then avoid it.
    A 2 stage F&W cast Iron pump is fine, even a cast iron flotec is fine.
    You can buy a cast iron pump from Sears, and you will be covered if you have problems. They will also send replacement parts to your house.
    Good Luck.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Not anymore Don. At one time Sears did sell a in-house version of the MSE Sta-Rite that was good.
    Good Luck.
    Feb 2010
    SE Texas-Coastal
    How do you know it's a 3 stage? All the 3 stage pumps I am aware of are at least a 1.5 HP, but I am not very familiar with the F&W brand as for some reason they have very little market share here.
    Quote Originally Posted by schudaddie View Post
    Mar 2011
    Houston, TX
    Quote Originally Posted by Texas Wellman View Post
    I think you are correct about that pump being 2 stage, not sure how it became 3.
    Sears still offer a few different brands. F&W, Wayne, Flotec to name a few.
    The Flotec 1HP 2 stage is still being sold. Runs on 120 or 240V, 12 GPM at 50PSI.
    http://www.sears.com/flotec-deep-wel...&blockType=G38
    Have Fun.
    Feb 2010
    SE Texas-Coastal
    Look again Don. That is sold by "Hardware Habitat". They are doing the same thing Amazon does. If they don't sell it they hook you up with someone who does and then take a little cut of the action.
    Have Fun.
    Apr 2012
    ct
    I can just imagine taking a pump into Sears for an exchange.
    Last weeks shoe salesman wouldn't have a clue about what he was looking at.
    Buy from a REPUTABLE supplier and get better materials with fewer hassles.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Quote Originally Posted by Wet_Boots View Post
    After an acquisition they usually cease production of the higher quality pump(s) when there are two or more similar products. Then they brand the lower quality pump with the names of all the companies they previously acquired. Now they have no competition, only one production facility instead of six, and six different names for many different retailers to sell the same pump. Which by the way doesn’t last as long as it used to, but there is no longer any option, so you just replace it more often.
    I can just imagine taking a pump into Sears for an exchange. Last weeks shoe salesman wouldn't have a clue about what he was looking at.
    In the early 90’s I saw a room full of warranty pumps at Sta-Rite (now Pentair). They said there probably isn’t anything wrong with 90% of them. But Sears bought so many pumps that they didn’t question a warranty, they just handed them another pump.
    Apr 2012
    ct
    That maybe true Cary, but Sears/KMart isn't the store it used to be
    Mar 2006
    Lubbock, Texas
    That was back when Sears was one of the only places a homeowner could buy a submersible pump. Now they sell them under many different names to all the box stores and let them cut each others throats (prices).
    Oct 2013
    michigan
    I had to contact F&W a few years ago for info on replacing the pressure switch. I gave them the date code and model number and that's what they told me. I also have a cutaway picture in my manual that looks to be a 3 stage (3 impellers) and my pump looks to have the same number but it's castings are so rusty it's hard to tell. I need to send them an email and see what they say. The guy I bought the house from had the motor replaced 4 times. In '88,'89,'91 & 93. The first time a possible lightening damage is mentioned on the receipt. Each time a 1 hp was installed. weird.... Maybe It started out as a 1.5hp. It is wired for 220v and I can read the tag on the motor as 1 hp. I'll let you know how this plays out...
    later
  1. Underslab drain replacement not deep enough for current code
    By emd36 in forum IPC Plumbing Code Questions
    Last Post: 11-13-2012, 10:30 PM
  2. Broken Cast Iron Flange too Deep for insert replacement
    By Chesapeake in forum Toilet Forum discussions
    Last Post: 10-03-2011, 10:48 AM
  3. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Solar and Geothermal Water Heating Forum
    Last Post: 04-20-2009, 09:33 AM
  4. Deep Well Jet Cleaning or Replacement
    By HELP!!! in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-26-2007, 09:48 AM
  5. Water Source Heat Pump Deep Pump Sizing
    By Greg-VA in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2007, 04:49 PM
