Thread: Delta Diverter R11000 - PEX?
    DIY Junior Member jdm127's Avatar
    Apr 2013
    Calgary, AB, CA
    Default Delta Diverter R11000 - PEX?
    We are installing a Delta diverter valve (R11000) for our basement shower. It will have 2 outlets, a fixed shower head and rain shower. Can we use 1/2 pex supply lines from the outlet ports on the Delta diverter to shower head and rain shower? We will be using copper from the rough-in valve up to the diverter.
    Since those are shower heads, you will be fine.
    Apr 2013
    Calgary, AB, CA
    What if I was to add 3 body sprays (0.9 GPM each). Could I use PEX for the pressure balance loop? Will the 1/2 pex from the diverter be able to supply both the body sprays and rain shower if they were on at the same time?
    Thanks again.
    I wouldn't want to gamble on that.
    I know for a fact that PEX run to a tub spout has so much restriction that it pushes water out of a shower head while filling a tub.
    I think I would run that loop in copper.
  1. Delta R10000 and R11000 question
    By Freddie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2013, 04:18 PM
  2. Delta pull down tub diverter
    By JOL in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2012, 09:00 AM
  3. delta diverter
    By larryf in forum Shower & bathtub Forum & Blog
    Last Post: 01-09-2011, 12:51 PM
  4. Delta shower diverter
    By Brander in forum Shower & bathtub Forum & Blog
    Last Post: 09-05-2010, 06:26 PM
  5. Delta Shower Diverter
    By mynewacct in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2006, 06:49 AM
