Results 1 to 8 of 8
Thread: will installing two water heaters work
    DIY Junior Member dichroic's Avatar
    Oct 2013
    Oregon
    Default will installing two water heaters work
    hello, and thanks for this forum.
    I have a small cabin I wish to rent. It has a 20 gallon, 110 water heater that is fine for two people. I would like to install a second 20 gallon 110 water heater next to the shower, which is only 15 feet away. Will I then have 40 gallons of hot water if I connect it into the existing plumbing lines? I don't want to have 2 separate zones, just one zone with 2, 20 gallon water heaters for a total of 40 gallons. If I separate it into zones I still only have 20 gallons going to the shower. I want the shower to use both water heaters at the same time. Will this work? I really don't want to have to install a 220 volt water heater if I don't have to. Thank to anyone who can let me know if my idea will work.
    In the trades Dana's Avatar
    Jan 2009
    If cold-input to the water heater by the shower is plumbed to the hot-output side of the original HW heater you'll get the full showering capacity out of it. If you try to parallel them by tying the hot outputs together, probably not. Shbrt draws from the tank by the shower will have a small "abandoned heat" penalty of water drawn from the first tank ending up in the plumbing between them, but that can be mitigated by insulating that line well (R4 minimum, not the crummy 3/8" wall R2 stuff sold at box stores.)
    Mar 2011
    Houston, TX
    How ever you do it make sure that your Cabin can support the extra electrical load.
    Cabins are not known to have large electrical systems.
    Are we getting spoiled yet ?
    Good Luck.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Often in hotels or restaurants there will be multiple hot water heaters. In most cases all the tanks are located in one room. The cold line goes to a tee and then splits to go to each tank. The hot outlets go to another tee so that there is one hot line. In these set-ups there are unions and valves so a heater can be removed and replaced or worked on etc without a big impact on the hot water.
    I your case it might be cheaper and easier to just replace the 20 gallon heater with a 40 gallon heater.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Smooky View Post
    I agree.
    You could use 120V elements, and would not need all of the extra headaches.
    Have Fun.
    Jan 2009
    I suspect that were there space for a 40 gallon tank, there would already be one...
    Most 120V 20 gallon water heaters are set up with elements to work on a 20A breaker.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Dana View Post
    I bet you are correct.
    Cabins are not like living in the hotel, and some heaters are put under the floor. Very little head room.
    Can I say Spoiled again ? Oops, just did.
    Have Fun Everyone.
    Oct 2013
    Oregon
    thanks everyone. yes the cabin is small and the current wh is in the kitchen next to the sink. it's the old modular steel kitchen insert from the 50's. looks like the best thing is to install a 40 gallon one and by pass the 20 entirely. I have a 50 amp stove breaker that is free as I have a gas stove. Taking out the 20 gallon will give me that breaker free also. Should have plenty of power. Can I just cap off the cold going to the current 20 and tap into the cold for the new 40 about 15 feet away?
    thanks again
    donald
  1. Installing gas heaters & tankless water heater, Jacuzzi J-sp-180w
    By Randyj in forum Tankless Water Heater Forum
    Last Post: 04-14-2013, 07:39 PM
  2. Installing 2 electric heaters
    By Jrahn in forum Water Heater Forum, Tanks
    Last Post: 02-14-2013, 02:39 PM
  3. Replies: 4
    Last Post: 04-04-2011, 01:45 PM
  4. Installing a 4 gang new work box--install another stud to support it?
    By ironspider in forum Electrical Forum discussion & Blog
    Last Post: 03-04-2010, 05:56 PM
  5. Does a dual water heater installation require that the water heaters be the same size
    By GooSkinBaldi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2007, 02:28 PM
