Results 1 to 2 of 2
Thread: Replacing bathtub p-trap
    DIY Junior Member Tree fingers's Avatar
    Oct 2013
    Utah
    Question Replacing bathtub p-trap
    I am replacing my old bathtub but once I had the old tub removed I noticed that the tub's brass p-trap connection was rotted out. The far end of the brass p-trap pipe is stuffed inside an ABS pipe which then leads to the main waste line. My question is, well, what should I do? The brass pipe is in the ABS pipe very tightly so I'm not sure if I can pull it out with out breaking anything. Would I be better off cutting through the brass pipe and using a compression fitting?
    Thanks in advance for all advice!Name:  image.jpg
    The ABS has a trap adapter on it, with slip joint nut and washer. It takes tublar fittings, which is what your brass tub drain is.
    You could use an ABS tub waste and overflow, and glue with coupling to the 1.5" ABS pipe.
    There should be a p-trap in there somewhere.
  1. HELP! Replacing this P trap
    By malbrax in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-19-2013, 03:17 PM
  2. When does a bathtub trap become a running trap?
    By smartnewb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2013, 06:03 AM
  3. Replacing Cast Iron Shower Drain / P-Trap & Replacing with ABS
    By n0teye in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2011, 02:36 PM
  4. Queston on replacing bathtub drum trap - questionable existing?
    By mckeand13 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2007, 07:27 AM
  5. replacing bathtub cartridge
    By Mikein in forum Shower & bathtub Forum & Blog
    Last Post: 04-20-2007, 02:55 PM
