Results 1 to 12 of 12
Thread: Is there a decent Flapper MOD for the Rialto
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Is there a decent Flapper MOD for the Rialto
    I've been holding off replacing it till a remodel. Just due to the color of the toilet...matching the sink and tub.
    Anyhow, this Rialto is on my last nerve...
    It just leaks one way or another. I replaced the flapper (again) a couple months ago. Less then 6 months I suppose.
    It has been problem free until it acts up, which is recently. It just won't sit properly. I've adjusted the slack on the chain one notch, moved the position where it sits, etc.
    Somebody has to come up with a flapper that is 3/8 larger in diameter so it wont hit the overflow , but is ~larger~ so that damm thing sits and seals.
    For all you plumbers who see this everyday....is there a fix, or is it time to take it out to greener pastures.
    How about a picture of the inside of the tank?
    Sometimes you can bend the trip lever and make it pull from a better position.
    Jun 2006
    Here goes for a pic.
    There is litterally about a hair less than 1/8" of play where the flapper seats.
    If only the design was smigen wider.
    Anytime you see a toilet that pulls the flapper to the side like that will give you problems once it softens a little bit (happens faster if there's lots of stuff like chlorine in the water).
    Jun 2006
    It's official. It broke the camels back...
    Ultramax II on the way.
    The intent for this bathroom on the next remodel was a wall hung unit...grrr.
    The trip lever on that Kohler looks to be pulling it from the side. It's too bad they don't have a longer rod on that.
    Jun 2006
    Paging wjcandee
    Ultramax came in today.
    Off to Lowes tomorrow to pickup that MaxPerformance Korky Valve....
    You seem to give it a much higher praise than the stock
    If you have the Korky valve in your new toilet, it's a waste of money to swap it out for essentially the same valve! If you have the other brand they sometimes use (it has a plastic screw on the top), I'd still wait until it dies, and that could be a VERY long time, unless, you had one that was too noisy.
    Jun 2006
    Yeap. I have the other brand. I remember another post.....WJC praises the Korky much higher than the one that is included.
    Master Plumber Caduceus's Avatar
    Oct 2013
    Pittsburgh, PA
    It's a good thing to get a replacement. After dozens of Kohler Rialto rebuilds, I have found that the flush valve seal is the biggest problem more so than the flapper, but also the best replacement parts for the rebuild are the very expensive Kohler kits. A better investment in buying new.
    General Contractor dx's Avatar
    Jul 2005
    Michigan
    I've had a Rialto in my own house for about 10 years now. It never worked right from day 1. As Jad and Terry correctly observed, the trip lever pulls the chain at an angle. I have lengthened the trip lever on mine and that moved the chain to a more vertical pull. Still, it occasionally leaks. New parts don't solve the problem. As I said, mine never worked right since new. It's the most expensive toilet in my house (it's black) and also the worst performing.
    I have repaired many Rialtos, and it has always worked the first time, but you have to insert the "hinge" into the right slot on the back of the flush valve.
  1. Kohler 1-pc Rialto flapper leaks
    By Muggins in forum Toilet Forum discussions
    Last Post: 05-29-2013, 08:48 PM
  2. Got a decent Shock! Ouch.
    By pogue1000 in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2009, 05:43 PM
  3. Gawd Damm Rialto - flapper or valve
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2007, 11:26 AM
  4. Need help finding DECENT manufactured home kitchen sink
    By atheria in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-27-2006, 05:34 AM
  5. decent framing nailer
    By coach606 in forum Remodel Forum & Blog
    Last Post: 07-10-2006, 09:54 AM
