Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Low-voltage switch circuit.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Default Low-voltage switch circuit.
    I've seen one or two homes that had wall switches without any line voltage in them. I'm not sure what history would lead to someone having a rack of relays in the basement utility room sending power to ceiling lamps.
    One set of switches I recall involved something more practical, and that's why I'm posting this. These switches were controlling lights in and around a swimming pool, but with all the power coming from the pump room in the pool cabana. I remember these switches weren't controlling relays, but were closing a secondary circuit in some sort of transformer arrangement that I can't recall. I'm pretty sure the closed switch in the secondary circuit made for an increased magnetic field that was used to close contacts, so the function was like a relay, only there was no specific coil with a voltage rating needed to operate it.
    Any of this ring a bell? I rather liked the simplicity of the concept. I saw a data sheet for these low-voltage (or nearly "no-voltage") switching devices, but I just can't remember enough to locate them again.
    Jun 2007
    North Carolina
    Low voltage switching of lights was a big thing years ago. What I have dealt with had a master control located in the master bedroom that controlled all lights.
    What you seem to be describing at the pool is X10 switches.
    http://x10pro-usa.com/
    Mar 2007
    Metro NYC
    Definitely not X10. Much more low-tech. Strictly transformer wiring and magnetism. The control circuit wasn't labeled as having any particular voltage or current. It was a UL-listed device, and not a home-brew circuit.
    I should add that this particular device could have predated the transistor - it was that low-tech
    Mar 2011
    Houston, TX
    Default Must be FM
    Quote Originally Posted by Wet_Boots View Post
    Was it Magnetism or Hypnotism ?
    http://www.astrologynspiritualism.co..._hypnosis.html
    The only system that I have seen like that used SCR's and Flux capacitors.
    Mar 2007
    Metro NYC
    I think the circuit diagram would look a bit like two transformers in a series connection, with the low-voltage switch interrupting the interconnection between transformers. I'm sure it's something more subtle, though. There might be a parallel winding involved.
    Mar 2011
    Houston, TX
    It may have been like these,
    http://www.douglaslightingcontrol.com/specifications
    Would be great for a Smart Home.
    Have Fun.
    Mar 2007
    Metro NYC
    It must be something that was always obscure. I don't even remember how I located a diagram of its inner workings, in pre-internet days. I don't think it used anything but wires and magnetism to accomplish the task, and it did so without step-down transformers and relays.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    It sounds like some kind of magnetic amplifier.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    I think the circuit diagram would look a bit like two transformers in a series connection, with the low-voltage switch interrupting the interconnection between transformers.....
    .....I don't think it used anything but wires and magnetism to accomplish the task, and it did so without step-down transformers and relays.
    So which is it?
    Mar 2011
    Houston, TX
    Quote Originally Posted by ActionDave View Post
    So which is it?
    This has to be one of those 0 phase systems.
    Sounds like FM.
    Mar 2007
    Metro NYC
    My memories just can't quite connect the dots. Since there was supposedly very little power/voltage in the control wires, I think that probably rules out a circuit where you can see a turns ratio on a magnetic core. And yet, closing the circuit represented by the control wires would alter a magnetic field enough to open and close power contacts.
    You see the circuit diagram, and you get it, is about all I can add. And that even goes for my grudgingly obtained schooling in magnetics, where a weber is a charcoal grill, and a henry is the home run king.
    Feb 2009
    Colorado
    Sounds like an old R-7 relay system. 24V to switch boxes and remote latching relays to control the lights. Great system. Rugged, reliable, and flexible.
    Mar 2011
    Houston, TX
    Some of the newer systems are pretty neat.
    If you run DC you can go off grid without the need of inverters.
    With all of the Smart Meters used now a days, Remote controlling over the internet is getting popular.
    Have Fun.
    Jun 2007
    North Carolina
    Here we are in agreement and one of the best on the market. I own two of them, one charcoal the other gas
    Now I must give a little rebuttal on this as Henry is the best darn rifle ever made
    Mar 2007
    Metro NYC
    A google search is not much use. Too much product out there accomplishing the same task with modern electronics. I might someday find an invoice that gives me the location where these switching units are probably still in place, and I might request a peek at them.
  1. Trying to rig a variac switch to slowing raise the voltage on an old tube amp
    By CanOfWorms in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2013, 12:45 PM
  2. Why do I have voltage when switch is off?
    By Randyj in forum Electrical Forum discussion & Blog
    Last Post: 04-28-2011, 01:42 PM
  3. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  4. Installed new low voltage recessed lights - now switch hums
    By taysan in forum Electrical Forum discussion & Blog
    Last Post: 05-02-2008, 04:39 PM
  5. Circuit still has voltage?
    By Will Jones in forum Electrical Forum discussion & Blog
    Last Post: 03-03-2008, 08:26 AM
