Results 1 to 9 of 9
Thread: Leaky drain in an awkward place. Lead bend
    DIY Junior Member bobparks's Avatar
    Oct 2013
    Brattleboro, VT
    Default Leaky drain in an awkward place. Lead bend
    This is a leak in an old joint between a copper sink drain and lead toilet soil pipe. The connection was done by soldering the copper sink drain into the side of the lead pipe. It's a terrible connection that I've managed to limp along using some quick-drying material from the hardware store. I know, I know, the best thing to do would be to replace the flange at the toilet, cut back the cast iron pipe a few feet back and replace everything with PVC. But that's going to be expensive and take a long time (I'll have to remove a new toilet from the bathroom above to put in a new flange.) So . . . any materials I could use to plug the leak good enough? I tried re-soldering it, but it was too dirty to take. It's in an accessible enough place to fix if it every happens to leak again. Many thanks. Bob
    You probably do not have anything hot enough to solder to the lead, without melting it. That connection would be almost impossible to make using any "conventional" method.
    Oct 2013
    Brattleboro, VT
    That makes sense. I tried to melt it back together with mapp gas, but it was a total failure. I will redo the whole system.
    DIY Member ImOld's Avatar
    Jun 2013
    In the rumble seat
    Kids of today! Here's what real plumbers used back in the day with a bar of solder. No problem with that lead pipe. One practical item of note when putting a refrigerator in a confined space.
    The side, center area of the refrigerator sometimes has a bulge to it. I would not purchase one with a quarter inch tolerance.
    This looks to me like a bigger project than you are equipped for. It is in an awkward location to work on with heat, and the material you have to work with require know how and the proper tools. Might be best to call for professional help on this one.
    You would have to be VERY proficient to solder a lead pipe with a torch. There is a very small heat range between melting the solder and melting the lead pipe. You need a big "soldering iron", actually a "soldering copper", to do it. The "attachment" on top of that blow torch is to hold the soldering iron in the flame until it gets hot.
    Jun 2013
    In the rumble seat
    I guess I was VERY proficient hj!
    Actually all I ever remember doing is removing old lead pipe with a blow torch.
    Here's a few items from my day including the soldering iron mounted.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I would love to see someone use one of those torches
    Here is some more lead piping. The lead bend on the toilet above goes to a cast iron stack outside the home, installed in 1910, Seattle.
    The smaller lead lines are the tub on the left and the lav on the right.
    There appears to be a leak at the wye.
  1. awkward..how to seal drain pipe???
    By scrappy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2009, 06:42 AM
  2. TGI lead bend!
    By Howard Emerson in forum Toilet Forum discussions
    Last Post: 08-13-2008, 06:37 AM
  3. Replace lead bend tub drain pipe?
    By Seth in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2007, 06:20 AM
  4. Lead Drain Bend Question
    By djc621 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2007, 08:35 PM
  5. should I replace the lead bend
    By rblick in forum Toilet Forum discussions
    Last Post: 05-29-2006, 07:25 PM
