Results 1 to 8 of 8
Thread: I think I messed up
    DIY Junior Member annagibs's Avatar
    Sep 2013
    Cleveland
    Default I think I messed up
    The p-trap doesn't line up with the glued-in tee. What do I do?
    Sep 2013
    Cleveland
    Maybe something like this with a 90 to connect it?
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Put a 22.5 or a 45 degree elbow in the pvc pipe and then install the trap adapter. Make sure everything lines up before you cut and glue it all together.
    http://www.homedepot.com/s/webapp/ca...l#/?Nao=24&c=1
    Sep 2013
    Cleveland
    Thank you Smooky, how close to the wall should I glue the 22 or 45s to the wall to make the offsets connect?? Is there a rule to this?
    Jan 2008
    Put the new bend near the wall where it allows the trap to line up the best. The trap arm must remain horizontal, with not more than 1/4" per foot of pitch towards the drain in the wall.
    YOU put the fitting wherever it works the best. Right at the wall might not give you enough room for the trap, and too far out may put it too far from the sink's tailpiece.
    Sep 2013
    Cleveland
    Okay guys you have helped me out so much. Now just need to know which would be the better choice.
    1.
    2.
    There is no "better choice". They are equal so go with the one that looks best to you.
  1. Two cesspools. I think the plumber messed this on up??
    By Robert Gravel in forum UPC Plumbing Code Questions
    Last Post: 07-23-2011, 08:03 AM
  2. I messed up - how to fix it?
    By JuanSigned in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2011, 07:27 PM
  3. Messed with new pressure switch.....
    By scarab138 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-08-2008, 05:40 PM
  4. Outside Sillcock, I messed it up, please help.
    By bchase in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-07-2007, 08:01 PM
  5. Old Messed-up Shower
    By luckybob343 in forum Shower & bathtub Forum & Blog
    Last Post: 01-26-2006, 11:22 AM
