Results 1 to 12 of 12
Thread: gallons used is not advancing on softener
    Default gallons used is not advancing on softener
    My softener Fleck 2510 electronic timer stopped advancing at 554 gallons. I did a regeneration and now it wont advance past 950 gallons (normal regeneration amount) What is the likely cause and fix for this? Thanks.
    Dec 2009
    Alaska
    Are you saying that it will not count down to Zero?
    Either the meter is jammed as in not turning or the probe is not sending the signal to the computer board.
    Which meter is in use? the 3/4 turbine or the paddle wheel?
    To check the sensor at the meter end take a magnate and pass it close over the end and check for flashing water drop, flashing means the wire is good and that the meter is jammed and needs to be cleared.
    I am not sure if it is a 3/4 turbine or not. I will try with a magnet. It did go through a regeneration last night and then actually counted down from 950 to 943 but seems to be stuck there, the dot does not flash when water is running. How do I clear a jammed meter? Thanks
    Dec 2009
    Alaska
    Put in bypass, start a regeneration and then start to break down the system before and after the meter assembly and make sure that the turbine for the 3/4 if free wheeling by blowing through it.
    For the paddle wheel part, dome comes off and make sure that there is nothing blocking the wheel in the housing, there could be some thing in the dome so flush out the dome and bang on palm of hand a few times to see if any thing comes out.
    more times than not the turbine is the choice and the little wheel is jammed.
    Thank you I will give this a try when I can.
    Mar 2011
    Houston, TX
    Quote Originally Posted by vegashomes View Post
    Did you remove power from the controller ?
    Sometimes removing power for a bit will reset the controller, when it gets into a hose mode.
    Just a thought, if it is not a mechanical problem in the flow impeller.
    Good Luck.
    Dec 2009
    Alaska
    If it is the SXT timer, that will hold the clock for up to 36 hours with no power..
    It does not take much to stop the 3/4" turbine wheel from turning, just one piece of resin can do it.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Akpsdvan View Post
    Very true.
    Sometimes you can clear debris buy using very high flow, without taking it all apart.
    It may just need to be replaced, if it don't work on lower flow, but works on high flow.
    Not sure what min is on that setup. Will it detect a toilet flush ?
    Have Fun.
    Jan 2012
    California
    The 2510 turbine is subject to wearing out. The impeller gets worn on the main internal shaft. This is not repairable and may need to be replaced. This typically lasts 5-15 years in a residential application. It is easy to replace, but it is very expensive.
    This is one of the reasons I prefer the 7000, the meter is less than half the cost of the 2510 meter and it tends to last much longer.
    Mar 2011
    Houston, TX
    If it does need replace, here is one for $69.00 at the bay.
    http://www.****.com/itm/Fleck-SXT-tu...-/141042484452
    Not a bad price, because other vendors want around $159.00
    Have Fun.
    Jan 2012
    California
    Wow, best price ever for that. Definetly a good catch!
    Mar 2011
    Houston, TX
    Not sure about the seller, but paypal will back you.
    Only 3 left for sale.
    I could use one for a backup, but mine is still working.
  1. 750 gallons between regen cycles?
    By starwmyers in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-02-2013, 03:50 AM
  2. 1000 gallons of water fit into 100 ft well!
    By uberchik in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-16-2010, 10:31 AM
  3. Draining 10 Gallons per minute
    By Timster in forum Shower & bathtub Forum & Blog
    Last Post: 03-30-2010, 06:53 AM
  4. Water usage 100,000 gallons per month?!
    By TequilaMB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-23-2008, 05:47 AM
  5. Gallons per minute
    By Siestabob in forum Irrigation / Sprinkler Forum
    Last Post: 12-20-2007, 07:17 PM
