Results 1 to 5 of 5
Thread: Garbage disposal drain????
    DIY Junior Member Slfrat's Avatar
    Sep 2013
    Calgary
    Default Garbage disposal drain????
    I realized after the fact that this isn't the correct way to install a drain on a garbage disposal. Question is, is there anything about the way it was done that could cause problems?
    Yakima WA
    It's hard to tell what you have because your picture shows black on black, but I think if those 2 P traps are connected, you have an illegal S trap. ABS pipe and fitting are cheap, so I would just remove the whole mess and start over and do it right.
    It is NOT an "S" trap, nor is it a "double trap", but the trap at the disposer is useless and not necessary. The tee that the disposer is connected to is upside down. So other than these two "defects" and it not being how I would have done it, it is a good DIY kludge. You could also reposition the weight on the sink hose so you could pull the spout out further.
    This would be cleaner. Remove the 90 bend that came with the disposer and pick up a disposer kit with baffle tee.
    Yakima WA
    The new picture helped me see what you have. It still is a mess and I'd redo it.
  1. can't get drain out for new garbage disposal
    By tim123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2013, 01:25 PM
  2. Drain for garbage disposal
    By MattE in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2009, 08:40 AM
  3. washer/garbage disposal drain
    By SRICE1417 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2009, 01:18 PM
  4. Drain from Garbage Disposal
    By RPO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 04:53 AM
  5. Garbage Disposal drain/waste pipes
    By Bobbi B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2006, 10:44 AM
