Results 1 to 13 of 13
Thread: DIY annual vinegar flush--how much pump?
    DIY Senior Member guy48065's Avatar
    Sep 2013
    SE and north MI
    Default DIY annual vinegar flush--how much pump?
    My question is how much volume is needed to flush the heat exchanger? Is it necessary to use a big submersible 1200GPH pump like I've seen on Youtube--or would a smaller system using maybe a 80GPH condensate pump do the job? The condensate pump or a cutting fluid tank/pump from a lathe would make a nice system.
    Is it the chemical that's doing the work--or the turbulence of a high-volume pump knocking the crud off?
    Romeo and Atlanta, MI
    The acid dissolves the water soluble mineral deposits...super high velocity isn't required or desired. You do need a pump that won't be destroyed by the (mild) acid, though. My unprofessional opinion...
    Sep 2013
    I suggest you do a search for "phosphoric acid" scale "on demand" " water heaters".
    I am no expert, but I would use diluted phosphoric for that. It is not poison when diluted. It is even used as a food additive. I expect it to be much more effective than vinegar. One advantage to vinegar is that it comes pre-diluted, so you cannot get that wrong.
    I used phosphoric acid to clean an old water heater to get stuff out. I also used liquid laundry detergent next. Then I put an electrical protective anode into that water heater. I also installed a nice filter that has stopped the black and red stuff from forming. Phosphoric acid is available at Home Depot in a place not related to plumbing or cleaning. Klean-Strip Phosphoric Prep Etch. Very strong. I can't tell you how much to dilute it, so you could buy a pre-mix. http://www.speedclean.com/products/t...intenance.aspx
    Don't rely on me. Do your own study. The fact that I did it does not make it right.
    Sep 2013
    SE and north MI
    Let me ask it this way...most people pay a pro to do this job. What pump do the pros use?
    Master Plumber kcplumber's Avatar
    Feb 2012
    Overland Park, KS
    We do lots of water heaters but rarely get a call to service a tankless water heater. You should be fine with just purchasing an inexpensive pump from the hardware store. I would definitely recommend just sticking with Vinegar, I know that some additives could void the warranty provided by the tankless water heater manufacturer.
    Mar 2011
    Houston, TX
    Quote Originally Posted by guy48065 View Post
    Not sure you would want to spend the money for a pump like the pros use.
    You can get a 1200GPH pump like what is used for a pond that has a in and out.
    http://www.webbsonline.com/Item/Calp...FWpp7AodFTIA1w
    For safety the pump should be used on a ground fault interrupt.
    A smaller pump will work, just let it run longer, since you are not paying by the hour.
    Some places around here will charge $200 for this service.
    Good Luck.
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    I use a small 1/6 HP submersible pump from Harbor Freight. Add a 5 gallon bucket with about 3-1/2 gallons of Vinegar and two washing machine hoses (if you have tankless service taps) for circulation. I've performed the service on my Rheem condensing tankless twice since I self installed the unit over a year ago. Pretty easy, since the addition of the water softener kinda retards calcium build up.
    Adding the 25% off coupon from popular magazines makes this a winner!
    http://www.harborfreight.com/16-hors...ump-68422.html
    Sep 2013
    SE and north MI
    Do you use that pump without a valve to throttle down the flow? 1350GPH through the small tubes in a tankless still seems like overkill to me?
    Mar 2011
    Houston, TX
    That pump does not make that much pressure, and will not achieve 1350GPH in that application.
    Feb 2005
    the vinegar is the only solution to run through one of these tankless
    heaters, I have heard you should run it , or cycle it through with
    a 5 gallon bucket for a couple of hours...
    the cost to have it done is pretty high in Indianapolis
    I know of one plumbing shop that charges $300 bucks....
    I wont get involved with any of it....
    dont need any call back issues or get blamed
    that the unit is not working properly after the job is done....
    Mar 2012
    Southern CA
    Like said by DonL, no way that pump will flow 1350com in the above configuration. In all actuality, the flushing process is very uneventful. I just let it run for 45-60 minutes while i do some other chore in the backyard. When finished, I flush with system with clean water using the same pump and bucket. I then put the clean hoses and pump into the bucket with a lid and store them together till the next use.
    No need for some special high dollar pump when the one I posted can be had for under $50. If you still feel uneasy using it for the mild acid, then spend $15 on the extended warranty. They will just give you new one and throw the bad one in a pile.
    Sep 2013
    SE and north MI
    Sounds like a plan.
    It's under $43 with the 20% coupon I found. I don't think I can do better than that.
    Thanks.
    Mar 2011
    Houston, TX
    Sounds like a plan.
    Thanks.
    Did you count the $10 for a good 5 gallon bucket ? . lol
    Have Fun.
  1. Does Annual teeth x-rays cause cancer ?
    By DonL in forum Ian's Corner
    Last Post: 05-01-2012, 03:19 AM
  2. Replies: 4
    Last Post: 11-17-2010, 08:04 AM
  3. Annual Problem
    By rennellsmc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2010, 11:47 AM
  4. Annual gas boiler service
    By pedietz in forum HVAC Heating & Cooling
    Last Post: 10-14-2007, 10:42 AM
  5. Vinegar on fixtures
    By alleycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2007, 09:19 AM
