Results 1 to 6 of 6
Thread: drain help connecting p-trap
    DIY Junior Member annagibs's Avatar
    Sep 2013
    Cleveland
    Default drain help connecting p-trap
    I have 1 1/2" collars, I need help attaching the p-traps. What needs glued in the 1 1/2" collars to attach the p-traps?
    You would need a trap apapter.
    Either a standard female to trap, or a spigot to trap. The trap side would be a slip joint nut and washer.
    The other side would be a solvent weld (glued) fitting.
    Sep 2013
    Cleveland
    Thank you Terry!
    Is this question about two different sinks, because one photo shows an elbow and the other one a T?
    Sep 2013
    Cleveland
    Yes two different sinks, but same dilemma. I bought a ptrap adapter to plug into the 1 1/2" drain hub. It has threads a washer and hand tighten plastic nut threaded on Is that what is done usually?
    Yes. We use those trap adapters, either hub or spigot depending on whether you are gluing into a hub or onto a pipe.
    The p-trap is tubular and can be assembled using your hands. Easy to remove and work with.
  1. Connecting smaller bathroom sink drain to a large P-trap?
    By Bratan in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2013, 05:58 AM
  2. connecting trap to galvanized nipples
    By bbillcee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2011, 12:59 PM
  3. Connecting plastic sink drain to metal p trap
    By DIYhell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2010, 02:09 PM
  4. Connecting P-trap to drain for tub
    By vinceliberto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2010, 05:30 PM
  5. Connecting to Cast Iron P-Trap
    By gransom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2009, 07:12 AM
