Connecting 220V Stenner pump
North Carolina
Can I connect a 220V Stenner pump to the load side of a 230V pressure switch or will the higher voltage burn out the Stenner pump? If so, why would they even sell 220V Stenner pumps, since the majority of well pumps are 230V?
My well pump appears to be connected to a 250V/30 Amp double breaker.
DonL
Houston, TX
As long as the switch can handle the extra current then yes, It will work fine.
220 can go up to 240V or more in some areas.
You can look up the specs if you have a model number.
Good Luck.
