Results 1 to 5 of 5
Thread: Riser Clamp Size
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    Default Riser Clamp Size
    I want to cut out a section of cast iron waste pipe, and before doing so, install a riser clamp on the floor above.
    The pipe is 3 1/2" OD - I figure this is what they call 3" waste pipe?
    All I've been able to find on the net (and Grainger) are 3" riser clamps. What do you think?
    If a hammer won't fix it, it's an electrical problem.
    I think, but do not know for certain, when they are referring to a 3" riser clamp, they're referencing the ID of the pipe...most of those I've seen are two parts that clamp around the pipe, and the OD has some leeway. Most drain pipe has about 1/4" walls, so 3.5" is about right for the OD.
    It would be a 3" riser clamp
    A 3" waste pipe would take a 3" pipe clamp.
    Jun 2010
    Thanks guys.
  1. 4 inch riser clamp
    By rockycmt in forum Remodel Forum & Blog
    Last Post: 09-26-2009, 10:03 PM
  2. Riser clamp
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 09-22-2009, 10:38 AM
  3. Banded Clamp
    By gsici in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2009, 08:27 AM
  4. riser clamp questions
    By skip22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2007, 07:04 AM
  5. clamp or screw.
    By kellyb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2006, 08:35 AM
