Thread: Water Lines AFTER Pressure Tank
    DIY Junior Member akcooper9's Avatar
    Sep 2013
    North Texas
    Default Water Lines AFTER Pressure Tank
    Had a well drilled a month ago. The well piping is 4in sch 40 casing with 1in sch 80 for the sucker tube (probably wrong name sorry guys) to the top of the well seal. I need to make some plumbing adjustments and run some lines to the garage etc. Can I use sch 40 for this or do I need to keep sch 80?
    Jan 2008
    Outside of the structure I would use polyethylene tubing that is listed and labeled for use with potable water.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Sch 40 PVC is preferred outside the casing and much, much cheaper.
  1. Water in bottom of tank - and - hot water in cold lines
    By SteveRiley in forum Water Heater Forum, Tanks
    Last Post: 11-03-2012, 03:15 PM
  2. Replies: 13
    Last Post: 07-14-2011, 08:18 AM
  3. Possible frozen lines, no pressure in tank though.
    By AllIwant4XmasIsH2O in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-16-2010, 09:20 AM
  4. Air in faucet lines after installing new water tank and non submersible pump
    By lucymo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-24-2008, 06:51 AM
  5. Low hot water pressure, air in the lines
    By GFC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2006, 04:03 PM
