Thread: flush problems on american standard wall hung toilet with tank.
    DIY Junior Member ikanfixthat's Avatar
    Sep 2013
    richmond, va
    Default flush problems on american standard wall hung toilet with tank.
    1983 what looks like American Standard wall hung toilet is slow to flush. The new ones keep mentioning power assist, mine has standard fill tube and flap as in any toilet. I have checked, holes under rim they are clear, cant see or feel the bottom tube from tank to check, poured water 3 1/2 gallons from bucket with same result of slow. Properly vented on 3 inch wall waste line. Do you think this had an assist flush of some sort and a homeowner put regular parts in it? My guests always complain and it takes 2 to 3 five gallon flushes to clear waste. No name under top or tank back other than a the word "waterline" , 4.9 and a number 9248. Help?
    Apr 2012
    New York, NY
    Can't help you on most of this, but one thing I can tell you is that if this was a pressure-assist bowl, it would basically not flush at all if the homeowner tried to put in a flapper and fill valve. The bowls are a very different design. We had a member here try that to make a flushmate-type toilet more quiet, and the result was that when he flushed, the thing made a slight gurgle and basically no water drained from the tank.
    The current AS Glenwall apparently flushes pretty well with the pressure-assist, and is relatively-easy to install.
    The parents home has a 1962 gravity glenwall, and a newer Flushmate assisted Glenwall.
    The water goes out more slowly out of the 1962 bowl, but it still works for them.
  1. American standard wall hung 4040 tank/white
    By corycov in forum Toilet Forum discussions
    Last Post: 06-29-2010, 02:13 PM
  2. Which carriers for older american standard wall hung
    By robertbible in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2009, 06:01 AM
  3. ~1965 American Standard Wall Hung Help
    By TJanak in forum Toilet Forum discussions
    Last Post: 09-11-2009, 09:33 AM
  4. American Standard flush problems
    By ppinc in forum Toilet Forum discussions
    Last Post: 08-15-2008, 09:58 AM
  5. American Standard tank warped ... problematic flush valve
    By Lakee911 in forum Toilet Forum discussions
    Last Post: 06-09-2008, 04:49 PM
