Results 16 to 30 of 42
Thread: Repair of replace advice
  1. #16
    DIY Junior Member rfreda's Avatar
    Sep 2013
    NJ
    not to be an ingrate guys but can you please take your lead content fight anywhere else but on my thread!
  2. #17
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Just because you have lost resin does not mean the unit will use more salt than it use to. Some of the reasons for using more salt are: an adjustment was made to the amount of refill, an adjustment was made to the meter wheel causing a regen sooner, the brine valve is not seating properly dripping water into the brine tank between regens. To check this, simply remove the brine line from the valve and see if it drips. A leak in the house will cause more regens which will use more salt. I hope this helps.
  3. #18
    Nov 2010
    Maine
    A toilet with a leaking flush valve is a prime suspect.
    Its not just your thread, we fight on most of them LOL,
  4. #19
    Mar 2011
    Houston, TX
    lol
    Could also be the cheap salt that is being used.
  5. #20
    Quote Originally Posted by rfreda View Post
    WHOA nj DUDE!! I'm thinking that just maybe that old brass valve you have had for the last 20 years has been leaching too much lead into your water, or I could be really hurt by your attitude....
  6. #21
    Mar 2011
    Houston, TX
    lol
    That might explain my problem my problem my problem.
    Lead never affected me me me.
  7. #22
    Nov 2010
    Maine
    Who are hou people and why am I here?
  8. #23
    Mar 2011
    Houston, TX
    I think time will tell if the new stuff will last a long as the old school lead containing stuff.
    It has not been long enough to compare yet.
    Only time will tell.
    But my bet is the old stuff is better.
  9. #24
    Sep 2013
    NJ
    LOL. no attitude here! I'm just a newb that wasn't aware you guys enjoy arguing with each other and don't discriminate where you do it!
  10. #25
    Jan 2012
    California
    We have done accellerated low-no lead brass testing, so far it is much better, but it is much more expensive, harder to machine, and in many cases can be replaced with stainless for a comparable cost.
    A topic that is rarely discussed is the efficiency and capacities of resins over time. It is rarely brought up because most softeners are not set to regenerate at depletion, but well ahead of depletion. If a softener loses 10-20% of its capacity over time (normal) most people would never know because the systems regenerate well ahead of the time the resin becomes wxhausted.
    20 years old... can you budget for a new softener yet? It would not be a bad idea, maybe not totally necessary since it appears you have a very high end unit to begin with.
  11. #26
    Sep 2013
    NJ
    Here's a couple pics of my control valve. I just added 80 lbs. of salt as I usually keep it around half full, let's see how long it takes before the salt hits the water line in the tank and I need to add more.Name:  WS 1.jpg
Size:  85.4 KBName:  WS 2.jpg
  12. #27
    Jan 2012
    California
    Neat! That is a rare find. The cost of the brass meter was very expensive (and still is) and made it a rare item on the 2500 control valve. That thing is built like a M1 Abrams Tank and is easily serviced and maintained. All of the parts are still readily available, and that valve is still manufactured, though very few are sold nowadays. If you open the timer, you will see the date stamped on a white sticker next to the micro-switches.
    Do you have a bypass? Most residential valves now have a bypass as an easy to install option. The 2500, 1500, 2700, 2750 did not have that and required a divertaflo or 3 valve bypass. The 2510 is a nearly identical valve, but in plastic and with a bypass option.
  13. #28
    Nov 2010
    Ocala, Florida
    Looking at that valve has brought a tear to my eyes. I remember making bypasses for that unit. One think that looks to be very normal with that valve. It appears that the brine valve is stuck in the open position.
  14. #29
    Sep 2013
    NJ
    Quote Originally Posted by mialynette2003 View Post
    thanks guys, nice to know this is good stuff even if it's 20 years old. I have to pull the receipt but i do remember it not being cheap back in 1993. If the brine valve is stuck open do I need to get that fixed?
  15. #30
    Mar 2011
    Houston, TX
    Yes, If it is sticking it will need to be repaired.
    Good Luck.
  1. When to repair - when to replace?
    By shendrick in forum Water Heater Forum, Tanks
    Last Post: 12-31-2012, 11:57 AM
  2. Repair or Replace?
    By momof6 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-18-2010, 09:20 AM
  3. Repair or replace?
    By adamw in forum Water Heater Forum, Tanks
    Last Post: 12-13-2009, 02:38 PM
  4. Repair, replace, or????
    By david3394 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-10-2009, 01:32 PM
  5. Need Advice: Repair or replace system
    By hans_idle in forum HVAC Heating & Cooling
    Last Post: 09-11-2008, 06:50 AM
