Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Where to drain water softener?
  1. #16
    Feb 2011
    NW Ontario, Canada
    One is the drain and the other is the vent.
  2. #17
    If you look at the picture, the tub is upstairs and the drain goes down through the floor so the water in the tub would be higher than the air gap that he wants to install in the basement.
    Yes and I and my DIYer customers have installed a few thousand drain lines as I described without the problem you mention possibly happening. He said he'd use a Y for the trap connection to that drain line.
    The only way your problem can happen is IF there is a blockage past his trap connection to that drain line. And then only/maybe IF the tub is drained while the softener is in backwash or rinse at 2-3:00 AM.
  1. water softener drain
    By Joshuani in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2013, 09:20 AM
  2. Can I drain my water softener in a floor drain?
    By amateurplumber1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-15-2013, 09:18 AM
  3. New drain for water softener
    By cacher_chick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2009, 01:49 PM
  4. New water softener - no drain
    By beanie376 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-10-2009, 10:01 PM
  5. water softener drain
    By Leemonster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2006, 07:46 AM
