Results 1 to 8 of 8
Thread: How effective are heat traps?
    DIY Senior Member Murphy625's Avatar
    Jul 2013
    Michigan
    Default How effective are heat traps?
    Anyone have an opinion on installing heat traps on water heaters? Are they worth the extra effort and cost or just an over hyped extra thing that does very little?
    I would not install heat traps if you mean the nipples with floating balls. Those cause all kind of water hammer problems, and over pressure issues with the T&P.
    Jul 2013
    Michigan
    Mine doesn't have those type.. I was going to install the 6 inch "U turn" looping type that is made from the piping connecting the hot and cold lines.
    There would be no restriction with those. It does help prevent warmed water from drifting into the cold.
    Jul 2013
    Michigan
    I'm sure it does! But what I was wondering is if it was worth the extra effort or is it just a fad that doesn't save any significant energy?
    I mean, sure, technically the hotter water is going to go up into the cold water pipe but is it going to actually result in any measurable savings?
    Feb 2011
    NW Ontario, Canada
    I think it would depend on how the plumbing is run as to whether or not there would be convection. In my case, the both the hot and cold turn down and go under the floor so there would be nothing to add.
    I agree with Terry about those silly nipples. Mine keep screwing up and one of these days I will unsweat the pipes and rip them out.
    I was told in a store that the hot water electric tanks now have plastic in the top connectors where the hot water pipe goes. He said this helps prevent this problem of warmed water drifting. The pipe should not be warm to the touch beyond a foot. Does that make sense? I have two plumbers that said they don't do the "U", as that is mainly for large systems, not a small home hot water tank.
    Jul 2013
    Michigan
    Thanks for the replies.
    I decided to go ahead and use a stainless steel 24" corrugated flex connector to make the "U" turn.. (not the braided rubber type as I hear they're junk)
    It's all hooked up and working great! I insulated the stainless connectors and wrapped them up tight..
    The only thing I'm a bit disappointed with is the noise.. that darn power vent is LOUD!! You can hear it exhausting air outside and it makes a significant humming sound in the house..
    Oh well.. it should save me about $30 a month on heating bills as opposed to the electric water heater.
  1. Whirlpool Heat Traps, leave in place or remove?
    By spieg in forum Water Heater Forum, Tanks
    Last Post: 01-24-2013, 07:04 PM
  2. Internal Heat Traps
    By teague6403 in forum Water Heater Forum, Tanks
    Last Post: 08-09-2011, 07:54 AM
  3. Effective Sound management
    By alanrudy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2011, 04:17 PM
  4. Banging water pipes from water heater heat traps?
    By JimLS in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2010, 12:33 PM
  5. Cooked my heat traps and dip tube ?
    By pommeree in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2008, 03:37 PM
