Results 1 to 6 of 6
Thread: Can I put everything in one trench in slab?
    DIY Senior Member guy48065's Avatar
    Sep 2013
    SE and north MI
    Default Can I put everything in one trench in slab?
    My cottage remodel involves turning a room-on-slab into a mud room/laundry. For this to work I will need to bust out a trench across the slab over to the crawlspace where the bathroom is. Can I place hot/cold supply, washer/sink drain and electrical all in this same trench?
    Romeo and Atlanta, MI
    Mar 2011
    Houston, TX
    Yes you can, but you need to have the proper distance separation for your Local Code requirements.
    The wire will need to be rated for that use
    It should be under the slab and not in it, in my neck of the woods.
    Sep 2013
    SE and north MI
    Separation is a deal-breaker if they can't lay next to each other. Who would I ask--the building dept, electrical, or plumbing? Might I run into conflicting codes like I recently did with receptacle spacing over baseboard radiators?
    Mar 2011
    Houston, TX
    Where ever you get your permit would be the place to ask.
    You can look up the proper spacing and depth on the internet.
    It depends on where you live.
    Many places are happy to get your permit money and really do not care.
    Oops, Yes I did say that.
    Sep 2013
    SE and north MI
    Permits eh?
    I've been trying for weeks just to get the zoning guy to return my call. Small community.
    Keep it simple I say.
    Mar 2011
    Houston, TX
    Quote Originally Posted by guy48065 View Post
    Permits eh?
    It looks like 12" separation is used in most areas.
    And the water line should be 12" below the frost line.
    http://www.hcnv.us/bldg_dpt/document...ements5-08.pdf
    You should put warning tape in the trench also.
    Good Luck.
  1. Trench Depth?!
    By stew24 in forum Irrigation / Sprinkler Forum
    Last Post: 04-27-2013, 11:49 PM
  2. Trench for Sewer Line
    By rmelo99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2010, 08:29 AM
  3. Trench Cuts in Slab Floor
    By edwardh1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2009, 08:25 AM
  4. Cost of trench
    By DAGUS WYSONG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-18-2009, 05:46 AM
  5. Trench sharing
    By themoose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2007, 07:25 AM
