Ricleb
- Messages
- 5
- Reaction score
- 0
- Points
- 0
I own a 40 year old home, which is on a slab and am currently remodeling the master bath. The entire bath has been gutted from floor to ceiling and to include the wall that houses all piping and venting. After removing the tub I attempted to remove the tub drain/overflow which broke off. Thinking that the 1-1/2" drain was bad (corroded) I rented a jack hammer with intentions of
opening the slab back to the main vent. After removing approximately 6 to 8" of the slab I found that the line transitioned to 2-1/4" O.D. cast iron with a cast iron adapter that transitioned to the old p-trap. Knowing now that the line is in fact 2" I will go back whith my original plan of installing a shower in lieu of a tub. My questions are:
1. Due to availability I would like to install a center drain base. Should I cut the slab in an effort to achieve a more direct line to the main drain and install a 45 ell. Or should I cut to my existing rough in and install a 90 deg ell and then connect to the cast iron. Either way the drain would be no more than 5' to the main drain.
2. Should I just cut the cast iron behind the coupling and tie in pvc, if so what is the appropriate fitting to do this transition. It will be buried in soil beneath the slab.
Thanks in advance,
Rick
Thanks in advance,
Rick
