Results 1 to 2 of 2
Thread: Toto toilet dripping but can't find leak
    DIY Junior Member dansf's Avatar
    Sep 2013
    san francisco
    Default Toto toilet dripping but can't find leak
    I have a Toto toilet that makes intermittent dripping sounds that are driving me crazy. It sounds like it's coming from the bottom of the toilet, not somewhere in the tank, though there is no water build up anywhere outside the toilet. I did the food coloring test and the water isn't dripping into the bowl. Any advice on what this could be?
    Does it happen more when it is windy outside? Does the toilet in question have the UniFit adapter? Air pressure in the vents can cause the water to rock in the bowl...some can slosh over the weir and down the drain. Also, after a fill, it may take it a few minutes to equalize the water level. This is more noticeable on the older version of the Unifit (the newer ones came with some sound insulation on them). If you shut the water supply off, does the noise stop?
  1. Tub leak, stain in ceiling below - How to find leak???
    By Chuck1026 in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2013, 07:22 PM
  2. My 2 yr. old one-piece Toto toilet is dripping into the overflow pipe
    By Jack D in forum Toilet Forum discussions
    Last Post: 06-09-2011, 09:23 PM
  3. small dripping leak above zone valve?
    By tommyo in forum Boiler Forum
    Last Post: 10-24-2009, 04:24 PM
  4. Toto Toilet Leak
    By Rilands in forum Toilet Forum discussions
    Last Post: 08-01-2009, 11:09 AM
  5. where can i find the model # on my toto toilet?
    By bakchoi in forum Toilet Forum discussions
    Last Post: 10-25-2007, 05:10 AM
