Results 1 to 3 of 3
Thread: Wet vent with 4" stack
    DIY Junior Member peter.ar's Avatar
    Sep 2013
    Boston, MA
    Default Wet vent with 4" stack
    This question is mostly about _why_ plumbing code requires certain things.
    I am working on the 3rd floor of a 4 floor, 200 year old building. I recently had a plumber in to repair a leak in the 4" cast iron at the third floor. In the process he completely re-did the sink and washing machine hook up on the 3rd floor. The two fixtures tie into the 4" drain using sweep T fittings, the sink above the washer. This puts the two about 8" apart. On the fourth floor there is only a kitchen.
    The washer hasn't been connected yet, and my question is if it needs its own vent. There is a vent pipe that the plumber used for the sink, and I could branch off that and also vent the washer.
    Reading the code (Massachusetts) it seems that wet venting is explicitly prohibited if the fixtures involved are a sink or clothes washer! Go figure! But I can't understand why it would really help anything in this case. With a 4" main drain fed by only 2 1.5" or 2" drains, that 4 drain could never have enough water in it to siphon out the washer trap. Is there some other potential problem I am not thinking of? Or are they trying to prevent someone using a 1.5" diameter pipe as drain & wet-vent?
    Another assertion in the code is that a washer trap shall not below floor level. Why is this?
    Nov 2010
    Maine
    You can't plumb without a license in Mass. Especially in Boston.
    You can use the same vent for the sink and washer, re-vented at 42" or higher off the floor.
    For years we used to wet vent a laundry sink over a washer as long as the sink was run with 2" on the vertical. It's been years since I've been allowed to do that though.
  1. Best transtion(s) from 3" waste stack to 1 1/2" vent stack
    By lugnuts in forum UPC Plumbing Code Questions
    Last Post: 07-04-2013, 09:50 PM
  2. 2" Stack Vent
    By jpb123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2012, 06:00 AM
  3. how many fixtures on a 3" vent stack?
    By ballvalve in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2011, 01:29 PM
  4. Do you think a 3-1/2" vent stack is moronic? I do.
    By hawkeyeerik in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2009, 08:06 AM
  5. 2"main stack vent, big enough??
    By rheagle1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-20-2005, 06:12 PM
