Results 1 to 3 of 3
Thread: No hot water pressure in the shower
    DIY Junior Member gj92571's Avatar
    Sep 2013
    california
    Default No hot water pressure in the shower
    The hot water just trickles out of the shower head.
    I shut the water to the house off and removed the stem. Still only a trickle when I turned the water back on. However, when I turn the hot water on in the bathroom sink and then the cold water, water flows freely from where the stem was pulled and from the shower head when I put the stem back in.
    Any ideas?
    DIY Member WorthFlorida's Avatar
    Oct 2009
    Lake Worth, Florida
    Sounds like a typical problem with MOEN shower faucets. If you need to pull out to the handle to turn the water on and then turn it for temp control, it's a MOEN. Inside the cartridge there is a part that when shacking the cartridge in your hand you hear and fell the rattle. this somehow gets stuck. Remove the cartridge and tap it on the ground a few times and you'll hear. You can put it back in or get a replacement. There are all kind of hints on this site on how to remove the cartridge and it can be very difficult to do.
    Here is an entry that I did after replacing a MOEN POSI TEMP cartridge with a DANCO brand replacement. I had help both my friend and their daughter (two homes) with the same problem as you have. http://www.terrylove.com/forums/show...NCO&highlight=
    DIY Junior Member boblothrope's Avatar
    Jun 2011
    Massachusetts
    I have a problem with an American Standard R120 shower valve (the type where the lever moves up/down for volume, and left/right for temperature). Sometimes no hot water comes out. If the lever is all the way on the hot side, no water comes out at all. If I turn it back and forth, eventually there's a thump, and then the hot water flows.
    Nothing looks wrong with the valve. Is there anything I can try, short of replacing it?
  1. Water Pressure to Shower Head in Tub/Shower is Low
    By Milanomike in forum Shower & bathtub Forum & Blog
    Last Post: 03-09-2013, 12:45 PM
  2. Low shower water pressure
    By mmcrea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2008, 01:41 PM
  3. Low water pressure in the shower only.
    By Rughead in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2007, 04:00 PM
  4. water pressure in the shower
    By mudd in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2006, 12:06 PM
  5. replaced 1964 shower/tub faucets,now shower water pressure down significantly
    By very ignorant homeowner.. in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2006, 04:30 PM
