Results 1 to 5 of 5
Thread: Copper Pipe Mounted to Stucco?
    DIY Junior Member shanlar's Avatar
    May 2011
    Elk Grove, CA
    Default Copper Pipe Mounted to Stucco?
    Is it ok to mount copper pipe to stucco, as exampled in the picture below?
    That would be fine in California.
    It doesn't freeze where you are and stucco won't cause a problem.
    May 2011
    Elk Grove, CA
    Great thanks for the quick reply!
    Jan 2012
    California
    I am not to sure I like the exposed PVC pipe. At minimum, I would slap a coat of paint on it to keep the UV rays off of it.
    Central Florida
    ...and don't use an oil-based paint.
  1. Floor mounted or wall mounted toilet?
    By Guest in forum Toilet Forum discussions
    Last Post: 03-02-2014, 10:52 PM
  2. Our toilet was mounted 2 inches offcenter of drain pipe -- now what?
    By sombrerocat in forum Toilet Forum discussions
    Last Post: 11-20-2011, 12:16 PM
  3. Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2011, 10:44 PM
  4. Exterior repair/paint question on stucco
    By Agu in forum Remodel Forum & Blog
    Last Post: 06-19-2009, 05:58 PM
  5. How do you mount an outside hose bib to a stucco wall?
    By Verdeboy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2007, 10:07 AM
