Thread: Assembling Ductwork For Range Hood
    DIY Junior Member Leaky1's Avatar
    Mar 2009
    California
    Question Assembling Ductwork For Range Hood
    I am running 7 inch round 26 gauge metal duct for our kitchen and assembling five 3 foot sections for a long run.
    When I align all the seams I find one seam on top of another forces the walls of the mating ducts apart significantly. Would it be better rotate the mating ducts so the seams are four inches apart? I find doing this reduces the distortion of the duct walls.
    In addition, I am using three #8x1/2 screws to secure the mating ducts together and sealing the joint with UL Listed metal duct tape. Should the seams that run along the length of the pipe be sealed also with tape?
    Thank you for taking the time to read my post and consider my questions.
    Mar 2009
    California
    In case anyone is interested. I offset the seams by three inches and inserted one of the three screws securing each section between the offset seams. I used Polyken 339 to seal the sections and seams. I used CCWI-181 on the 90 degree elbow seams.
    http://polyken.com.mx/Archivos%20Pol...NICA%20339.pdf
    http://www.ductoutlet.com/CCWI_181_D...p/ccwi-181.htm
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I built one a few years ago with 8 inch pipe with an eight inch inline fantech exhaust fan. I used the foil backed tape at most joints and seams and no screws. I used neoprene lined clamps at the back draft damper and at the fan motor. The clamps reduce noise and make it easy to take apart and put back together.
    http://www.hvacquick.com/products/re...ntilation-Kits
  1. wall cap considerations for range hood
    By DanMc in forum HVAC Heating & Cooling
    Last Post: 11-01-2012, 01:52 PM
  2. Wall Vented Range Hood
    By K2 in forum Remodel Forum & Blog
    Last Post: 09-29-2010, 06:30 PM
  3. Convert dryer vent to range hood vent?
    By petergunn in forum HVAC Heating & Cooling
    Last Post: 11-10-2009, 03:42 AM
  4. Island range hood still leaking
    By DougieM in forum HVAC Heating & Cooling
    Last Post: 11-21-2008, 06:57 PM
  5. range hood
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 01-27-2008, 08:59 AM
