Results 1 to 8 of 8
Thread: cycling of pump
    DIY Junior Member rreith's Avatar
    Sep 2013
    michigan
    Default cycling of pump
    I sure you nice folks can help. A couple of day ago I noticed that my well pump started cycling a lot, so I looked at the pressure-it would drop to about 40psi and kick on the pump. pressure would come up quickly-within a few seconds, then shut off at about 70psi then drop back down to about 40 within about a minute. I suspected a leak so I shut off the valve after the tank and still the drop in pressure. I have determined that I losing pressure on the pump side. doing some reading I have assumed it is some sort of check valve or sifter valve. im not sure where these are located to check them. I have a red jacket 1/2hp submersed pump. thank-you very much for the help.
    Feb 2011
    NW Ontario, Canada
    If the pressure comes up within seconds, your tank is probably waterlogged. Do you have a bladder tank?
    The pressure loss could be a bad checkvalve or a leak between the pump and the tank.
    Sep 2013
    michigan
    I do have a bladder type tank. I assume it has kind of an air bag inside it. it has a vale stem on top of the tank. can I or should I check for water in there? How do I check for leak in between pump and tank. my pump is out in the back yard and tank is in basement. thanks so much for your help!
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by rreith View Post
    my pump is out in the back yard...
    In that case, the leak might be at the footvalve.
    Earlier you said you had a submersible. SO which is it, in the back yard or in the well?
    Sep 2013
    michigan
    My pump is a submersible in a well in the back yard. thanks.
    Feb 2011
    NW Ontario, Canada
    Ok, then split the system at the pitless. Lift the pump so you can cap the line with a Tee that has a pressure gauge and a schrader valve. Pump air in and see if it holds. If it doesn't hold, the leak is between the pitless and the pump. If it doesn't leak suspect a leak between the pitless and the tank.
    Sep 2013
    michigan
    Thanks- appreciate your time. Ill give it a shot.
    Mar 2011
    Houston, TX
    You need to drain your tank to make sure the tank has the proper amount of air in it.
    If your tank is waterlogged a leaking valve will seem to be a big problem, But you can live with a small leak short term if needed, If your tank has air in it. But the pump will cycle every now and then when no water is in use.
    Good Luck.
  1. Pump cycling
    By motovet123 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-17-2011, 11:58 AM
  2. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  3. spa pump cycling off and on
    By hockeydad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-05-2009, 11:24 AM
  4. Well Pump Cycling
    By chris_dale in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-10-2007, 07:17 AM
  5. Yet another self cycling pump
    By fohrman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-02-2007, 12:00 PM
