Results 1 to 12 of 12
Thread: Can''t get Pump Down to Mate with Pitless
    DIY Junior Member Eldonw's Avatar
    Sep 2013
    Indiana
    Default Can''t get Pump Down to Mate with Pitless
    I have a Wieses pitless adapter.
    Name:  Wieses pitless.JPG
    I have lowered the pump down the well. It hands up just before or right at where the adapter should be.
    The first time I needed it to go down 4 more inches and it would have been in place. I pulled it up to look at it and make sure that the lever was all the way down. Now it is hanging up a little further away.
    I am so close but so far! lol
    Moderator valveman's Avatar
    Mar 2006
    Are you sure the pump isn't hitting the bottom of the well?
    Feb 2011
    NW Ontario, Canada
    +1
    That would be my guess. Keep in mind that if the motor gets buried in sediment that it can lose needed cooling flow. Is the well top or bottom fed?
    Sep 2013
    Indiana
    I did wonder that but it is the exact same length as before. I am replacing a bad pump.
    I do not know if the well is top or bottom fed sorry. How do you tell?
    Feb 2011
    NW Ontario, Canada
    How deep is the pump set? How far down does the casing go? Is is screened? Is it a rock bore?
    The answers to those questions may indicate whether or not it is top fed.
    Sep 2013
    Indiana
    The pump is 65 ft. I do not know about the casing. I will have to figure out what the other things mean.
    Mar 2006
    It is not uncommon for you to have pulled the old pump out of 3 or 4 inches of sand, and now the new pump won't go back to the same depth. You can usually even see the line on the old motor where the sand had filled up to.
    Feb 2011
    NW Ontario, Canada
    Been there, done that. Twice I shortened the drop pipe to get by until I could get the sand blown out of the well.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Eldonw View Post
    Did the motor quit of did the wet end wear out from the sand? If the motor died from lack of cooling, consider putting a sleeve on the new pump after you get the well cleaned out.
    Sep 2013
    Indiana
    I do not know. It has rained here so I can not see anything on the pump that would tell me about the sand.
    How do you clean the well out?
    Sep 2013
    Indiana
    The pipe is schedule 80 I think. If I need to shorten it how should I do that? It is threaded and screws into the adapter.
    Feb 2011
    NW Ontario, Canada
    The DIY way is to rent a large compressor and shove the air line down the well. When you turn the air on, it will blow a lot of mud and water up into the air and onto everything nearby.
    My well guy did it with a tanker truckload of water and a 2" fire pump.
    A decade later, I did it the poorboy way when I could not get the well guy to come out. I made up an auger on the end of 60 feet of pipe and ran it down and tripped it back out several times. Then I put my old pump down the hole and pumped the mud until it ran clear. Got back 15 feet of casing that way.
  1. Unidentifiable Pitless / Problem removing pitless
    By tkraemer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-17-2013, 03:54 PM
  2. pitless adapter with piston pump
    By TonyC in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-30-2012, 08:16 AM
  3. How To Remove And Replace Pump In Well With Pitless Adapter
    By Regis Tration in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-14-2012, 07:24 AM
  4. new well dissimilar size pitless/pump discharge
    By MarkHash in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-26-2008, 06:51 PM
  5. Lond bang w/pump cycle & pitless problem
    By Model T Nut in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2007, 11:51 AM
