Results 1 to 2 of 2
Thread: Standard propane Water heater in a mobile home?
    DIY Junior Member DorBell's Avatar
    Sep 2013
    Modesto, CA
    Default Standard propane Water heater in a mobile home?
    I would like to know if I can use a conventional propane water heater in my mobile home. The water heaters labeled for mobile homes are twice the cost and lower efficiency. The current water heater is in an outside access cabinet with combustion air coming through a vent in the door. The cold water connects to the side but the plumbing can be easily changed. The mobile home is on a permanent foundation. The drywall lining the cabinet is 3/8 but also can easily be changed to 5/8.
    The only difference I have ever seen was that they come with anchoring straps to keep it from moving if the mobile home is relocated.
  1. Replies: 1
    Last Post: 03-17-2013, 02:36 PM
  2. Are mobile home sinks different?
    By griffy335 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2008, 06:41 AM
  3. New shower in Mobile home
    By Pewterpower in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2006, 07:09 PM
  4. Mobile Home Water Supply
    By Marshall in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2005, 08:11 PM
