Results 1 to 14 of 14
Thread: Pressure switch cycles on and off rapidly
    DIY Junior Member JMTFARMS's Avatar
    Sep 2013
    Missouri
    Default Pressure switch cycles on and off rapidly
    Pressure switch is cycling on and off rapidly. I thought there was a blockage between switch and pressure tank but cannot find any. I removed a pressure relief valve and left pipe open before pressure tank and have some water flow, but the switch still cycles on and off. Tried a different switch and had same result.
    Pressure switch is plumbed into a check valve (switch is on the pressure tank side of the check valve, check valve is installed in the correct direction). Could there be a malfunction in the check valve that is blocking flow after the pressure switch?
    Pump has a 2hp motor and according to the well cap is pumping 25 gpm.
    Thanks in advance for any replies.
    Mar 2011
    Houston, TX
    Your water tank may be waterlogged.
    Good Luck.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by JMTFARMS View Post
    Pressure switch is plumbed into a check valve (switch is on the pressure tank side of the check valve, check valve is installed in the correct direction)...
    You should not have a topside checkvalve unless that checkvalve is part of an airmaker (snifter). If there is a lot of iron in your water then it is likely that the air precipitated the iron and the line is now constricted.
    Sep 2013
    Missouri
    Tank is not waterlogged. Tank and system was empty and switch started cycling very rapidly. On off in one second or maybe even less. Switch still cycles with an open 11/4" pipe between switch and pressure tank.
    There is a lot of iron in the water and there is some deposits on inside of pipe, but I don't think there is enough deposits to cause a restriction. I do have some flow from the open pipe when the switch cycles. It is hard to tell how much flow because it surges as the switch cycles. Open pipe is less than 2 feet from check valve/switch with one 90 in between. I think a iron deposit clog in the 90 would have cleared when the pump and switch cycle.
    There was an iron filter on the system. The filter has been removed and a 1" hydro charger that was located before the check valve/pressure switch has been removed. There is now 11/4" line from the pump to the pressure tank. I think that the only thing that can be causing a restriction is the check valve. The pressure switch is plumbed into a port on the check valve. If something is loose or wrong with the check valve could it cause a restriction "downstream" of the pressure switch?
    The check valve can be removed by breaking loose two long time stuck unions. I tried some but could not budge them. I was hoping someone could tell me if my thinking was sound before I really try hard to get to the check valve. If anyone has any other ideas or anything else I should try I would appreciate it.
    Also is there any tricks to break loose the unions and fittings to get at the check valve? Will heat work? Oil? Any advice would be great. Thanks.
    DIY Member traveller's Avatar
    May 2012
    British Columbia
    How far, in piping, is the pressure switch from the tank? Perhaps you could post a photo of the pump and tank setup.
    Sep 2013
    Missouri
    Tank is about 3 feet from check valve/pressure switch. Pictures will have to wait till tomorrow. Thanks.
    Feb 2011
    NW Ontario, Canada
    I still say your line is restricted. If it is as rusted as you say then just take a sawzall to it and put in all new. Make sure the sense line goes close to the tank.
    May 2012
    British Columbia
    And this is a 2 hp submersible, correct?
    Sep 2013
    Missouri
    Yes, 2 hp submersible, 11/4" pipe. I do not know how old it is, but I do know it has not been pulled for over 20 years. It also makes a lot of noise when running. Noise was greatly reduced when I removed the hydro charger, but it is still louder than any other pump/system we have. Pump control box also hums noticeably when it runs now. Pump seems to still be pumping good when I bypass pressure switch.
    And Yes the sawzall will probably end up being the tool to solve the problem. But, who knows where I will stop if I start putting in everything new.
    Sep 2013
    Missouri
    Check valve was bad. Seal/plunger had broken loose and was creating a restriction. Thanks for your help.
    Mar 2011
    Houston, TX
    Nice Job.
    Enjoy.
    DIY Junior Member rreith's Avatar
    Sep 2013
    michigan
    Im having same problem with the starts and stops of pump. understand it could be a check valve or snifter? where are those located? thanks for any help. ive cut power to the pump temp. because im worried it will burn out if the starts and stops continue.
    Feb 2011
    NW Ontario, Canada
    You should start a new thread and not hijack this one.
    Mar 2011
    Houston, TX
    I agree.
    http://www.terrylove.com/forums/newt...=newthread&f=4
  1. Pressure switch rapidly goes on and off at cut in and eventually burns out.
    By Tom Luck in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-11-2013, 01:43 PM
  2. Pressure switch cycling rapidly at cut in
    By SWMICH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-11-2009, 05:23 PM
  3. pump cycles rapidly on/off nothing wrong with tank
    By rick21793 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-21-2007, 11:23 AM
  4. Pressure switch cycles quickly
    By daul10 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-15-2006, 06:24 PM
  5. Pumptrol Pessure switch rapidly cuts in/out
    By JWPH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-29-2005, 02:36 AM
