Results 1 to 6 of 6
Thread: Toto C744EF.10-01 & ST743S-01 Tank Type B fill valve Question.
    DIY Junior Member doogdoog's Avatar
    Aug 2013
    Honolulu, Hi
    Default Toto C744EF.10-01 & ST743S-01 Tank Type B fill valve Question.
    Aloha,
    I recently purchased a Toto C744EF.10-01 bowl with the ST743S-01 tank and was wondering if the fill valve should squeak when it shuts off. I originally purchased a C744E-01 bowl and ST743S-01 tank but I returned the bowl because it had something clanking inside of it. I decided to get the 10" rough in one instead and used the same tank (wife isn't pleased with the 1 1/2" height difference LOL). I am also have a problem seating the tank to bowl on the three high points on the bowl. I am left with about a 1/4" spaced evenly between tank and bowl so the tanks moves when flushed. Is there a slightly thinner tank to bowl gasket?
    Mahalo,
    doogdoog
    What's your water pressure? If it's overly high, that may be part of it. Without looking it up, Toto tends to use one of two fill valves, one is made by Korky for them, and the other (Vorato?). The Korky tends to be the quieter valve during shutoff.
    If your tank is nice and vertical, you can continue to tighten the nuts to bring things into contact...check out the 'How to' instructions posted here. Basically, tighten maybe 1/2-1 turn, alternating from side to side. As long as you don't end up porcelain to porcelain, you should not be able to break it unless the tank is defective. Since I don't do it every day, I'll put a sheet of paper under each of the 'legs' and stop when I can still pull it out. This means you've only got a few thousandth's of gap, but do have a gap and there's no chance of trying to stretch the porcelain (which doesn't work!) and cracking something. You may find it easier after the gasket has been compressed - IOW, it may be easier to do it now after it's been sitting compressed for awhile, but it will snug down.
    Aug 2013
    Honolulu, Hi
    Aloha jadnashua,
    The last time I checked the water pressure, it was about 65psi. but I will check it again. I'll try to tighten it a little at a time (maybe one day at a time) to allow the gasket to compress slowly and see what happens. I'll post a follow up after I am done.
    Mahalo,
    doogdoog
    DIY Junior Member martyd's Avatar
    Sep 2013
    CONNECTICUT
    I have a new Drake with the type B fill valve and it also squeaks at shut off. Maybe it's a "feature".
    Marty
    Aug 2013
    Honolulu, Hi
    Aloha martyd,
    I hope squeak is not a "feature" of the valve, but if it is, I am going to change the valve to something else.
    Mahalo,
    doogdoog
    Aug 2013
    Honolulu, Hi
    Aloha jadnashua,
    My tank is solid now but it is not sitting on the 3 knobs. I bought some transparent looking gizmos that you stick on the bottom of items that you don't want sitting directly on what you don't want it to sit on. It is round and about 1/2" in diam. and 1/4" high. I reseated the tank again and tightened it so it still had about 1/4" space between the tank and bowl. I slid the gizmo on the bottom of the tank while pushing it a little so I could slide in the filler between the three knobs. The tank is firm and even with a gentle push, it feels solid.
    Mahalo,
    doogdoog
  1. Replies: 33
    Last Post: 05-09-2013, 05:42 PM
  2. Replacement for Toto GMax fill valve - type A
    By JD231 in forum Toilet Forum discussions
    Last Post: 08-24-2012, 07:36 PM
  3. Where to buy trip lever for Toto Drake ST743S?
    By geepondy in forum Toilet Forum discussions
    Last Post: 12-17-2009, 08:16 AM
  4. Toto Drake ST743S toilet tank compatibility
    By Patrick C in forum Toilet Forum discussions
    Last Post: 03-02-2009, 04:46 AM
  5. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
