Results 1 to 5 of 5
Thread: Mounting heavy wall hung sink
    DIY Junior Member raevon1's Avatar
    Feb 2014
    North Carolina
    Default Mounting heavy wall hung sink
    Hi,
    I purchased an American Standard wall hung Surgeon's Scrub sink to use as a laundry room sink. It weights 123 lbs, and has a metal brace that came with it, and two brackets to hang it. (See photos below.) Do I need to install additional wood bracing inside the wall to support it or will the brackets do the job?
Size:  15.5 KBName:  american-standard-9047.044.020.jpg
    I wouldn't want to mount it except into solid blocking or into a stud in the wall. What does the installation instructions say about it?
    Jan 2008
    123 pounds with the potential for a couple hundred more if someone decided to lean on it too hard. I would double up the studs in the wall and use that opportunity to make sure the drain in the wall was the right height and position.
    It comes with a wall bracket, which fasten to studs in the wall. The angle bracket lock it in place, besides giving additional support, plus the bolts at the front help level it. It has a conventional 2" strainer drain opening so it only needs a 1 1/2' drain pipe. They fit a specific place on the bottom of the sink so your inside the wall backing has to be in the correct place.
    builder:anti-builder dhagin's Avatar
    Jan 2014
    oahu
    What do the sink installation instructions say?
    What HJ said about the 1 1/2 drain.
    dana
    __________________________________________________ ______________________
    in my youth, i knew it all and treated folks like they knew nothing. after 3+ decades in the construction business, i came to realize that the more i learn, the less i know. now i treat folks as i want to be treated - with respect, no matter how little i know. :-)
    Note: please don't feed or quote trolls. thank you. :-)
  1. Mounting Bolts For Wall Hung Toilet
    By cleancondenser in forum Toilet Forum discussions
    Last Post: 04-04-2013, 04:02 PM
  2. p-trap location Changing from wall hung sink to vanity sink
    By k9mlxj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2011, 04:46 PM
  3. Wall hung bathroom sink lavatory distance to wall
    By Mike2187 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2011, 05:56 PM
  4. Wall hung sink anchoring
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2007, 07:21 PM
  5. tips for mounting wall hung toilet
    By Gymbo in forum Toilet Forum discussions
    Last Post: 07-11-2005, 09:18 PM
