Results 1 to 8 of 8
Thread: Portable A/C with heat and auto-fan shutoff ?
    DIY Member GG_Mass's Avatar
    Aug 2013
    Massachusetts
    Default Portable A/C with heat and auto-fan shutoff ?
    Is there such a product out there ?
    The portable A/C or window A/C that I've known so far, will keep running the fan until a timer shuts them off, or until manually shut off. The only part that starts/shuts according to the thermostat setting is the compressor.
    Are there any units that will shut themselves (and start themselves), including the fan, just like the central A/Cs do - according to the thermostat setting ?
    Thanks.
    Mar 2011
    Houston, TX
    There should be a setting on the fan control switch.
    Turning off the fresh air setting may help.
    What is your model ?
    To answer your question, Yes there is.
    Aug 2013
    Massachusetts
    I have a couple of window A/C , both are kenmore, thought I do not recall the models at this point. I'm sure they don't have any setting to stop the fan-by-thermostat.
    I am in the market for buying a new portable one, 12000 BTU cooling, 5000+ heat, with the feature I presented above being a must.
    Mar 2011
    Houston, TX
    Just look into the Star rated ones.
    They even have a remote, in case your to lazy to get off of the couch.
    I never understood a need for a remote control ? To turn the fan off ?
    I guess most of the window units have the remote now a days, because they know most people are to lazy to get up.
    Have Fun in your search.
    Aug 2013
    Massachusetts
    Yes, I did, so far, no finds.
    If you want one to keep heating the house, or keep it above a certain minimal temperature, just like a central A/C does. You really need a unit with full thermostat triggered on/off.
    Mar 2011
    Houston, TX
    Quote Originally Posted by GG_Mass View Post
    They are not made for that.
    Get a central heating unit.
    The small units are made for 1 room, not the whole house.
    Aug 2013
    Massachusetts
    Yes, I am looking for a unit for our living room.
    A central unit is out of the question, We don't have air ducts at home, nor the budget to add them.
    Mar 2011
    Houston, TX
    You can buy a thermostat that plugs into a 120V outlet. It opens and closes the AC power to the unit.
    Not sure if it will work for your unit, You provided no model number.
    Is your unit 120 or 240V ?
    Have Fun.
  1. Replies: 5
    Last Post: 09-19-2010, 08:48 PM
  2. Whole House Auto-Shutoff Valve?
    By Shinshi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2008, 06:15 PM
  3. Auto Water Shutoff
    By tonyn1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-27-2007, 04:44 PM
  4. New supply line with auto shutoff
    By SteveW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2006, 08:54 PM
  5. Laundry water auto shutoff
    By peterd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2005, 06:58 AM
