Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Connect lav drain directly into toilet
  1. #16
    I was assuming that option 1 was a santee going straight up.
    Since that is not the case, and since I don't think I even understand your drawing at this time, I will concur with hj on option 2, if that means the revents are at 42"
  2. #17
    DIY Junior Member econjon's Avatar
    Sep 2013
    California
    Just passed inspection! Thanks for all the help.
  1. Connect toilet directly over main drain. 3" clearance under subfloor to top of drain.
    By zx6e in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2012, 09:05 AM
  2. Can I connect PEX directly to water meter in basement? (NJ)
    By gil716 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-14-2011, 06:20 PM
  3. dishwasher drain directly into waste line
    By mjbraun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-27-2010, 06:42 AM
  4. Valve directly behind toilet: what do to?
    By davidz in forum Toilet Forum discussions
    Last Post: 10-03-2007, 05:30 PM
  5. Can I put solid caustic soda into the drain directly??
    By shinchan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2006, 08:53 AM
