Results 1 to 4 of 4
Thread: Converting deck-mount faucet to wall-mount?
    DIY Junior Member David95966's Avatar
    Sep 2013
    Oroville, CA
    Default Converting deck-mount faucet to wall-mount?
    I would like to convert a deck-mount faucet to wall-mount to make cleaning easier and avoid accumulation of water. At first I assumed I would have to reroute plumbing into the wall, but then saw this site which runs the plumbing through the backsplash. This fixture is out of my price range.
    How would I use off-the-shelf hardware to achieve the same result as this fixture?
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Less than brilliant idea.
    1. The body is held by one nut. In time the faucet will be out of level and it will get loose.
    2. The wooden supply lines cover back splash will deteriorate with leaks.
    3. To change supply lines, you will need to detach the whole cabinet in order to gain access.
    If you absolutely have to have a wall mount, stick to a traditional wall mount faucet.
    Wall mount faucets used to be popular, but they disappeared in the last 20-25 years. Go to any faucet shop and you'll see dozens of counter mount faucets available and only one or two wall mount available.
    quote; How would I use off-the-shelf hardware to achieve the same result as this fixture?
    You won't. Most of the cost of a faucet is for the "trim" pieces, and they are different for a wall mount faucet than a deck mount one, particularly the spout design. You can mount a deck mount faucet in the wall, or vice versa. The handles would work either way, but the spouts would NOT.
    Sep 2013
    Oroville, CA
    Thank you both for your replies.
  1. Adapting deck-mount tub faucet to wall-mount
    By adrury in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-09-2013, 06:23 AM
  2. Replies: 1
    Last Post: 03-21-2013, 09:13 AM
  3. Wall mount tub filler with deck mount controls
    By islandgrl in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2012, 06:17 AM
  4. Deck Mount Tub Faucet
    By newmex999 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2010, 06:43 AM
  5. What will it take to turn wall mount plumbing into floor mount?
    By Dandilyun in forum Toilet Forum discussions
    Last Post: 12-31-2007, 05:26 PM
