Results 1 to 12 of 12
Thread: Leaking Threads using Teflon Tape
    DIY Junior Member mtyakker's Avatar
    May 2013
    Indianapolis
    Default Leaking Threads using Teflon Tape
    Recently installes a Lako's Twist to Clean filter between my preasure tank and water softner. It was reccomended to me on this site to reinstall using unions on each side of the filter so that I could remove the entire unit in order to replace the internal filter. The Lako's has 1.5 inch male threads. I am installing the Teflon in the correct, clockwise direction, I have used thin and thicker teflon, I have used as little as three to as many as 6 revolutions of tape, no matter what I have tried I can not stop the leak. If I continue to tighten the fitting down ,and I am using a large pair of Channel locks by the way, the leak does not stop. I am completely stumped as to what to try next. Any advice would be appreciated.
    These are pvc unions, it's npt the union I am having a seal problem with, it is where I am threadind the female portion of the union onto the male threads of the Twist to Clean, always seems to be leaking at the bottom.
    You do NOT use pipe sealant or tape (it's not Teflon, it's generic PTFE) on unions! THey seal with a metal to metal connection of the ends. Tape in there can get in the way and prevent that. Some people do put a small dab of sealant on the mating surfaces, but it's not required to get a good seal.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    It's difficult to say without looking at it, as it could be one or more of many reasons. When you are dealing with PVC connectors, over tightening is not always the answer. There could be ab issue with the thread. Or the tape. Hard to say. What kind of union do you have? metal unions don't need tape.
    I see your frustration, just call a handyman plumber.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    For PVC a thread sealent might work better.
    http://www.homedepot.com/p/Hercules-...6202/100112544
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I ALWAYS install a union with the male headed in the direction of the flow. On the rare occasions we have a weep, usually an existing union, we put a small amount of RectorSeal on the face and then retighten the union.
    quote; I ALWAYS install a union with the male headed in the direction of the flow.
    I haven't heard any one say that in the past 50 years. And at that time it was only one "plumber" who had a few other odd ideas.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Smooky View Post
    That may work fine.
    The only time I have had problems is when using the made in China fittings and they do not tighten properly because the Pipe sizing is off.
    And it takes a lot of tape to get a leak proof connection.
    Sometimes I will just Glue it if it is not bottoming out, and it is PVC to PVC, but then there is no turning back. If it is bottoming out you can cut some of the male thread off.
    As far as the PVC unions go, the ones will the O-Ring do not leak at the union, and I use O-ring Super Lube.
    May be best to get a different Union, that matches the threads of that filter.
    Are them Twist II Clean filters any good ? Made in China ?
    Apr 2012
    ct
    I'm sure we have all developed our own practices over the years, but this was passed down to me by my grandfather who was a P1 here in Ct for years.
    Mar 2011
    Houston, TX
    Quote Originally Posted by craigpump View Post
    It it is better to have a plan, Than no plan at'all.
    May 2013
    Indianapolis
    Yes, I am very pleased with the performance of the unit, however I am getting silt up from my well that is still getting through the 140 mesh filter, but the backwashing/self cleaning part works very well.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    It might be that the male threads are a wee bit deformed, or undersized. I worked with some deliberately-off-spec female threads on PVC valves, that required a major overdose of teflon tape wraps on the mating male threads, being this was before modern plastic-compatible paste dopes.
    That Hercules pipe dope looks like an equivalent to the Megaloc I mentioned.
    quote; Obviously we want it repaired at no cost to us, but we do not trust the original contractor to perform quality work.
    AN "old wife's tale". I install the union in whichever direction it will be easiest to tighten the "union nut".
  1. White Teflon Tape
    By Noth Jersey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-04-2009, 02:53 PM
  2. Teflon tape
    By ked in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2007, 02:38 PM
  3. Teflon Tape on Plastic Threads
    By bakechad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2006, 05:12 AM
  4. can I use Teflon tape or something else??
    By art in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2005, 01:12 PM
  5. teflon tape on IPS threads with NPT nipple???
    By ny architect in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2004, 06:40 PM
